Upside down picture
Recently bought this hdtv and have been having trouble with the picture. within minutes of turning the tv on the picture turns upside down. nothing you do gets it to do right. you'd have to stand on you head to be able to watch. does anyone know what the prob is? the book that came with it gives no help with this...
    Genius:
  • 1,139 Answers
OK this would denote that somehow your deflection (verticle) has been switched. I would have to see what the service documentation has to say about this, if you can contact the manufacture and get the service documents I or someone else can actually help with this problem. It is actually a simple problem but the service documentation will show how to correct it properly.
Posted on Sep 18, 2007
SOURCE:
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and value..you can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
The TV turns on and shows a picture that you can watch and within 10 minutes the TV loses its picture, however, the light is still green. If you turn the TV off you can get the picture to come back after...
The issue here could be a capacitor within the power circuit. Also could be a power transistor that is faulty. On the easy part it could be a matter of reprogramming the unit but I doubt it.
Dec 18, 2017 | Hitachi 42HDT52 42 in. Plasma HDTV
I'm having trouble turning on my TV. when I turn it on the green light comes on then goes off a couple of times then goes off. I have to wait a few minutes then try it again a few times before it comes on...
hello my name is rico, you have cold solder in your power supply, you need to open the back of your tv and your tv boards upside down, so you can look cold solder and resolder it, before you damage your tv more. if you need more help, feel free to call me at anytime. 602-810-7149
Jan 07, 2011 | RCA HD52W56 52" Rear Projection HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Samsung HLN437W
REPAIR: Enter the service mode; under option menu DDP1010 (DDP1011, where
applicable) adjust the V-Flip option back to normal. If the problem continues
replace the DMD Board
Mar 02, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
Televison & Video Logo
424 people viewed this question
Top Televison & Video Experts
Ekse
