Cant find ip adrress
I cant find my ip adrress and gateway adrress for my thomon 576 modem router can you tell me it please because it is for xbox live
  • cjere12 Apr 18, 2009
    is that one (defalt gateway) both my ip addres and my gateway addres
    it still isnt working my xbox live connection test is falling and saying cant find static ip addres ...................what shall i do?
  • 62 Answers
On your computer, click start>run.
In the box, type <command> (without the brackets)
at the c:\doc&set\<username> prompt, type <ipconfig> (again, no brackets)
the line you are looking for is default gateway
Posted on Apr 18, 2009
  • charles raynor Apr 18, 2009
    no, it is not both. it is only your default gateway.
    use google (or your favorite search engine) with the search term "what is my IP address"
    I am sorry to say that failing what we have done so far, You will now have to go to microsoft to fix this issue.
    See if these help you out ok?
    support.microsoft.com/kb/950314
    upport.microsoft.com/kb/958431
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
For diagnostic purpases I need to obtain the IP adrress of my Zoom 5241 cable modem. My Asus router IP is 192.168.1.1. I recently purchased this modem to save rental fees on the modem that Comcast...
Just use command prompt, at the 1st moment when you connect your router, no matter LAN, USB or wireless/blue tooth or even HDSPA modems connection it will assign itself a port on your machine, to check what ip adress your Zoom 5241 cable modem got, go to Start, then run then type CMD for command prompt screen and in the console, type ipconfig/all on list you will find your router, simply find "default gateway" part and use that local adress xxx.xxx.xyz.xyz.
Please rate my solution :)
Apr 13, 2011 | Computers & Internet
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Jun 16, 2009 | Microsoft Xbox 360 Arcade
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont take ip anymore
go to your router. find what your ip pool is. choose an ip that is in that pool. set up your xbox's internet manually. you need the gateway, DNS, and everything (you can find this on your router online) this will give your xbox a static IP and might fix your problem
Aug 10, 2008 | Microsoft Xbox 360 Elite Console
Xbox & nat
  1. The most likely problem is that your Pc IP is on different subnet try and change your pc to dynamic i.e Obtain IP address automatically.
Dec 30, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
Xbox 360
Contact the people you get your internet from. tell them you need to register your xbox. I have the DNS issues when i visit my girlfriend at college since they dont like to keep the Download speed high for the students. always fails
Dec 16, 2007 | Microsoft Xbox 360 Console
How do i connect to xbox live with a router
Shared connection with a modem and a router
1. Turn the modem off, and then turn it back on. Then turn the router power off, and then turn it back on. This is also known as power cycling the modem and the router.
Power cycle the modem first, and then power cycle the router. To power cycle these devices, you should follow your manufacturer’s specific instructions. Here are some general steps:
a. Remove the power supply from your device.
b. Leave the device unplugged for 15 to 30 seconds.
c. Reattach the power supply to the modem by following the device manufacturer’s instructions.
d. Wait several minutes for the device to start and to establish a connection with your broadband provider.
e. Verify that the modem shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
2. If power cycling your modem and router does not resolve the problem, try connecting the Xbox 360 console to Xbox LIVE by using the modem only. This eliminates any configuration problems on the router. If this setup works without the router, there is probably a configuration issue with the router. See the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
3. Verify that your router's Dynamic Host Configuration Protocol (DHCP) service has been enabled. DHCP enables the router to assign IP addresses to the computers and consoles on your network when you go online. If you need help with this, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
4. If you manually entered an IP address, gateway, subnet mask and/or DNS servers in the Network Settings area of the Xbox Dashboard , verify that it they are correct. At this point, you can also set your IP settings to Automatic. To do this, follow these steps:
a. Move to the System area.
b. Select Network Settings.
c. Select Automatic.
5. If your ISP requires Point-to-Point Protocol over Ethernet (PPPoE) settings, try connecting to only the modem after you enter these settings in the Network Settings area of the Xbox Dashboard. Network Settings area of the Xbox Dashboard.
Note Some ISPs may require Point-to-Point Protocol over Ethernet (http://www.xbox.com/en-US/support/connecttolive/xbox360/resources/glossary.htm#ethernet) (PPPoE) settings, This means that you may need settings such as a username and password in order to gain access to your ISP’s network. If you are unsure whether you have to enter these settings, please contact your ISP support group. At this point, if you can connect directly to the modem, see your router documentation to configure the PPPoE settings correctly on the router.
6. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
If this works, there may be a configuration issue on the router’s Dynamic Host Configuration Protocol (DHCP) server. DHCP enables the router to assign temporary IP addresses to the computers on your network when you go online. If you need help with understanding DHCP or the configuration, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
Shared connection with a gateway device (combined modem and router)
1. Make sure that the gateway is turned on. A gateway integrates a high-speed Internet modem with a router.
2. Verify that there is network activity by looking for the sequence of blinking lights on your gateway that generally indicate Wide Area Network (WAN), Local Area Network (LAN), and connected power status.
Note These names will vary from model to model.
3. Turn the gateway device off, and then turn it back on. This is also known as power cycling the gateway. To power cycle this device, you should follow your manufacturer’s specific instructions. Here are some general steps:
c. Reattach the power supply to the gateway by following the device manufacturer’s instructions.
d. Wait for the device to start and to establish a connection with your broadband provider.
e. Verify that the gateway shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Be sure that this address is correct, or set your IP settings to Automatic in the Xbox Dashboard.
5. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
Shared connection with Microsoft Windows Internet Connection Sharing
1. Verify that you can surf the Internet from your PC. If you cannot surf the Internet, there is probably a problem with your Internet connection. Contact your ISP for support.
If you are using a USB modem to connect to the Internet, the modem will be listed in the "Dial-up" window as the connecter that you are sharing and that you have configured. To verify that Internet Connection Sharing configured it correctly, use the following steps:
a. Click Start, and then click Control Panel.
b. In Control Panel, double-click Network Connections.
c. Right-click your broadband connection, and then click Properties.
d. In the Properties dialog box, click the Advanced tab.
e. Click to select the Allow other users to connect through this computer’s internet connection check box.
f. Click OK.
Ethernet Properties
2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer.
3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK.
4. On the View menu, click Tiles.
5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation.
6. Enter manual settings in the Xbox 360 Dashboard for IP address, subnet mask, DNS address and gateway and test the connection: To edit the settings:
a. In the Xbox 360 dashboard, move to the System section.
c. Select Edit Settings.
d. Enter the following:
• IP Address : 192.168.0.2
• Subnet mask : 255.255.255.0
• Default Gateway : 192.168.0.1
• DNS server (Primary): 192.168.0.1
• DNS server (Secondary): 192.168.0.1Xbox 360: Test Xbox LIVE connection fails at IP address
Dec 06, 2007 | Microsoft Xbox 360 Console
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
David Payne
David Payne
