Question about Maytag EPIC MFW9700S Front Load Washer
Error code "F".
Going through wash cycle the washer stops with timer flashing between time left and F
    President:
  • 1,865 Answers
The "F" code indicates an electrical problem, possibly a faulting part. Maytag does not offer any guidance on this. FYI - Could be a bad control board
Posted on Apr 18, 2009
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Motor error with out error code.
use tech sheet to follow test routine. C:05 is Heater test. some steps take time. during normal operation if timer display flashes, may be indication of standby/pause. Door lock sw may be bad(intermittant)
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
286 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
