SOURCE: My Dell Inspiron 6000 Takes forever...
ok jess it sounds also like it might be a heat problem also. does your fan make loud nosies if so you may need a new fan for your laptop. try just closing your laptop for a while when this starts to happen or use your laptop in cold areas like a huge fridge haah jk no but if you notice your laptop getting hot just give it a break for about 20-30 mins.
SOURCE: mouse pointer is frozen on dell inspiron m5030
Thank you the Fn and button to the right of F12 enabled my laptop mouse. Appreciate the tip.
SOURCE: how do i replace the hard drive in my dell
You must remove the keyboard and palm rest to remove the hard drive also there is a hard limitation of 500gb,,,,
SOURCE: My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in
'Safe Mode' by continuously tapping F8 button after you switch On. The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System
Restore
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Now, Click on Next and System Restore will start and windows will take a
reboot.
Just try this and leave a feedback for next steps.
SOURCE: My 2 year old daughter
hi there,
To enable or disable the touch pad, press the touch pad function key (located on the upper row) on the laptop keyboard.
Nelson
Testimonial: "Thanks Nelson. Really appreciated. Great help."
