Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi 50UX57B 50 inch Rear Projection smearing...
Hitachi 50ux7b 1991 the screen smears... black to white, white to black... all colors show.... faces are dark and unclear
  • Anonymous Jun 28, 2008
    I have the same issue, the dark and light parts of the picture smear into each other. Also the picture is very dark with all types of input, making things like video games with very shadowy scenes to show up blue and murky. What types of components do i need to replace, if any... very technical description welcomed, as well as a schematics set so i can replace part by part.
    President:
  • 4,402 Answers
Try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
How do you fix a black and white wii screen
What exactly is the screen doing? Is it black? Is it smearing? Is it showing only some letters and then very smudged and very dark letters?
Since it is likely that the screen you are talking about is an LCD or LED device, it is a sandwich device that is made up of various layers of electrically conductive material. The letters are formed via impulses that come to the back of the device and which then light up certain points while leaving others dark. The result is the display.
If the display is smearing, then it is likely that the conductive gel is leaking a bit within its cell-like space or it is likely that the rear electrical contact pad has been damaged, perhaps by an overvoltage condition. In this case, there's not much that you can do, other than replace the device, if that is at all possible (some devices are integrated into the device itself and the only way to repair it is to replace the entire device -- plug-out-plug in).
If the device is black, then it indicates the it is gone and has to be replaced. The same is true only if some segments are showing while others are not.
Let me know if this helps.
Feb 02, 2015 | Nintendo Wii Console
Hitachi tv showing only programmes in black and white menus still display colour
try changing the color system to ntsc 3.58..on the remote control
Jun 06, 2014 | Hitachi C29-F800S 29" TV
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Adjustng crt colors
put on a black and white channel and adjust to best black and white
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Color on the T.V. i think is gone
Ok what we need to do here is determine if the picture tube is still good or not??.. If you turn the tv to a station thats has a brighter scene and turn off the color what does the pic look like ??is it Black and white or a certain color overall on the screen??
Apr 02, 2006 | Hitachi 36FX48B 36" TV
Hitachi 50UX57B 50" Rear Projection Television Logo
394 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
