Question about Linksys Wireless-G WRT54GS Router (e125894)
Error 321 'ethernet not connected' on LINKSYS WRT54GS
Hi, I wastrying to configure my new LINKSYS WRT54GS wireless router through the installation CD. I have connected the ethernet cable from mode to router's "internet" port..and then the blue ethernet cable (that comes along with router) from router's port 1 to my laptop's ethernet port. At step 5 during installaion, i get this error 321 saying ethernet not connected, even though the conecton was fine. There is nor problem with the ethernet adaptor of my laptop, as the internet works just fine if I conect it with modem directly wthout the router. I have tried all the standard troubleshooting techniques like restarting router after 60 secs and restarting the modem after 30 sconds..etc. When I connect the router, I was able to login to the SETUP page 192.168.1.1...I have enabled "mac cloning" under SETUP...the subnet mask was 255.255.255.0 and ip address 192.168.1.1. There was another field for DNS server.I tried giving 192.168.1.1 for DNS server but was rejected. How do I get this router working? What do I need to do? Can you let me know the reason for error 321 even as the ethernet is connected and working fine? Is manual configuration a solution? If so, ca you help me with what to fill out manually in the setup page? Thanks a bunch!
  • wmanojin Apr 18, 2009
    Thanks for your response. I tried all these standard troubleshooting techniques. Itz a brand new router and was configuring for the first time. So I have put in the installation CD and was follwing the steps. So yes, I have restarted (hard reset) the router, but of no use.I did that for the modem too. :( I have manually changed the settings in 192.168.1.1 site...internet type as PPPoE ...rovided the correct username and password of the ISP.
  • Jerry May 11, 2010
    It sounds like you've done some configuration changes to your router that it may not have liked. Have you tried doing a hard reset to your router? Your Linksys router should have a small pin hole in the back of the router. While powered on, put in a very small nail or safety pink through this hole and hold it for over 5 secs. You should see all of the LED's on the front panel power on/off. Try resetting your wireless router and see if the error duplicates. Best of luck.
    Scholar:
  • 30 Answers
Dont go with the error , i came across such instances on a few occasions while users were installing it from CD . (Sounds lamme?right)
Try doing the set up manually , by accessing the web Gui of router .
***FOLLOW THIS********
The GS comes set to 192.168.1.1 as its factory default and with its built-in DHCP server enabled. So all you'll need to do is plug in a client that's set to obtain its IP address information automatically, maybe do a DHCP release / renew (or reboot your client computer), and enter the default password into the login box that pops up. If all goes well, you'll get the main Setup screen.
The Internet Configuration Type selector automatically refreshes the browser screen to present settings appropriate to the choices of Automatic Configuration - DHCP, Static IP, PPPoE, PPTP and Heartbeat Signal (for Australian users) Internet connection types.
MAC address cloning gets its own page in the Setup section, as does setting up either dynamic DNS service from dynDNS.org or TZO, setting up static routes or disabling NAT features and converting the GS to a non-NAT router.
The interface is generally quick, with quick mini-reboots needed to get the changes you make on each page to take. Multiple admin logins are allowed, with no warning given when two or more admins log on. Once you're logged in, there's no idle timeout, and you just need to remember to quit your browser when you're done, because there's no logout button.
Enabling Remote Management for the first time still pops up a message telling you to change the router's default password and you can now enable secure (HTTPS) admin access. You can also change the default remote admin port from 8080, but can't restrict access by IP address or domain. Also of note is that you can't reboot the GS from the Admin interface.
Let me know if you require any more assistance.
Posted on Apr 19, 2009
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
Hi I dont have the installation cd for my Linksys WRT54G Router and I need to install it on another pc. also the WLAN light is not lit.
You can configure your router with below method without disk. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 21, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Error 321 linksys WRT120N
Are you trying to run the CD that comes with the router ?
You get this error when your computer is not able to connect to the router.
Actually you can say that it is a bug in the CD.
Even if your computer is connected to the router, it will say that it is not connected.
You can set up the router manually without the CD.
make sure that your computer is connected to one of the Ethernet port on the router.
Reset the router for 30 seconds. wait for 1 minute.
unplug the power to the router and plug it back in.
Wait for a minute and try to set up the router manually.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
May 20, 2010 | Linksys Wireless-G WRT54GS Router...
Error 311 no wired adapter detected
For that right click on my computer icon then click on property then hardware-<device manager.
Then you can see all driver list click on network adapter and enable it.
You can configure your router without disk too.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 16, 2010 | Linksys Wireless-G WRT54GS Router...
Router Issues
Reset it.. Then plug into a LAN Port. Just http into it. To see if it works.. Let me know how it turns out.. www.ywaitsystemservices.com
Dec 15, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
KEEP GETTING ERROR 321 WHEN SETTING UP LINKSYS WRT54GS ROUTER
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Cannot finish installing
It means you have to plug in your computer to the router through a ethernet cord. Most computers have one, and on the back of thats router has 4 ehternet female ports. Plug it in, and run it again.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
3,500 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
