Question about Vizio P42HD Television
Vizio P42HD TVThe LH side of the screen is black - no picture with vertical fixed lines
  • jvectorvisua May 03, 2009
    left hand side of the screen is blank with different colored bright verticle lines of various hues going down that side of the screen. Every time it is turned on that side is still not working but the lines have changed position and color and number of lines - very random.
  • Anonymous May 14, 2009
    Please describe the specifics of your problem below. We'll add your post as a comment to shellydeals's "Vizio P42HD TVThe LH side of the screen is black - no picture wit" problem, and notify you when a new solution is offered.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
Feb 29, 2012 | Vizio P42HD Television
I have a vizio p42hd TV. It has thin red vertical lines evenly spaced about 3/4" apart throughout the viewing area.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO FIX IT.....
May 18, 2011 | Televison & Video
Our Vizeo P42 purchased in July 2005 has had a red vertical bar on the left side for about two months. About a week ago it developed vertical lines across the left half of the screen with no picture...
sadly no.
either your panel has been hit and damaged or the panel itself is failing.
without some sort of warranty coverage, your repair cost would exceed the price of replacement.
Apr 12, 2011 | Vizio P42HD Television
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
Two vertical red lines.
need to replace main board. it can't be repaired. check vizio parts web site for availability
Usually, they good with parts supply
Take care,
Alex's TV Service,
Philadelphia,PA.
215-806-5980..
Jan 22, 2010 | Vizio P42HD Television
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
ORANGE OR RED VERTICLE LINE DOWN RIGHT SIDE OF SCREEN?
hi..the probelm is due to the video circuit board.
only when you have a problem with the video
circuit board you will get such type of faults.so
you have to check the video board immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Vizio P42HD Television
Vizio p42hd sound no video just color bars
Replace your sustainer boards and that should solve the problem. These are the two vertical boards on the sides of your TV.
Dec 15, 2008 | Vizio P42HD Television
Vizio P42HD Television Logo
258 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
