If you wish to get more details, check these sites. It has set up codes, and setup procedure to many popular brand remote controls. Surf through, and find which brand remote control have set up codes to your Technica TV/DVD combo, and try the codes stated there first. If you're unable to synchronize the remote control you've bought, try a code search method. If any code that the remote control have, to sync with your TV, you'll won. Otherwise, buy an other one, hich have setup codes. Brand name of the remote control isn't a matter, but its codes list must have setup code to your Technica combo. Check the sites. Good Luck.http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press 'Enter'
or view it in Mosaic / Timeslide option.
Try this link too. http://electronicshelponline.blogspot.com/
SOURCE: Universal Remote Control cannot find code
I have the RCA RCU600D remote and i cannot get it to work with any codes listed for my Panasonic DVD-RV20 dvd player. Any ideas???
SOURCE: remote control code/daenyx tv/dvd combo
Your TV is made by Daewoo and is distributed by Daytek. If you call the 800 number on the warranty card you will reach Daytek.
So, what you need to know is this:
#1. A lot of new products won't have a website available. That does not
say anything to their quality or the company, just that you've bought a
new product and you're one of the first purchasers.
#2. A lot of times if you buy a "no name" TV, you're actually getting
components inside the TV that are made by brand name manufacturers. For
example, "Prima" uses LG panels in some of their plasma TVs (as well as
Daytek). How do I know this? Because I'm the authorized service
provider for Daytek, and Prima and quite a few other "no name" TVs, and
I've been working on LCD and Plasma since they came out, as well as
having worked in the electronics repair industry for over 20 years. I
own an Insignia 42" LCD and am quite happy with it.
#3. Most new products that have remote controls will not have codes
available for them no matter what brand of universal remote you buy.
You have to wait for the people who make the universal remote to have
time to make a code for this new brand of TV. This can take up to a
year for cable companies, and cheaper universal remotes may never get
the code. Expensive universal remotes may be able to have their
firmware updated through the internet, so adoption of new codes for new
products may happen faster.
#4. Stores like Walmart and Costco are excellent places to buy products
like this because they usually have a "no questions asked" return
policy if you get the TV back to the store within the stores time limit
for returns (some stores are 15 days, some are 30 days, phone the store
and ask them). I had purchased a 40" Digistar LCD TV from Walmart what
had a flickering problem, I took it back the next day without any
problem at all. Then I bought a 42" Insignia Plasma TV from Future Shop
that I wasn't happy with. I took it back 3 days later and had no
problem at all. As long as you know the stores policy for returns and
follow the policy, you won't have any problems either.
#5. Try to avoid buying big-ticket items from smaller stores unless you
know their return policies. Some smaller stores will not accept returns
on LCD monitors, TVs or plasma TVs but instead require you to
handle any problems through the manufacturer.
#6. Best bet it to call Daytek and ask them if they know of any universal remotes that work on that particular model.
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
SOURCE: cannot find the code for a Sabre Model No. LCT320BKA television
I have a comcast universal remote and can't find remote code for plasma 42" lcdtv.pls help
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
