Question about Kenmore 80412 Microwave Oven
Maytag microwwave oven
No heat..fan,lites,turn table, power setting are normal.... no manual so I try checking the power setting..I tried the preset food setting...reset the clock ..no results..
  • 67 Answers
Check the magnitron and capacitors one of this bad
Posted on Sep 19, 2007
SOURCE:
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 29, 2014 | Microwave Ovens
Maytag Microwave over Oven: comes on with lite and table turns; loud continuous noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 21, 2011 | Maytag 2.0 Cu. Ft. Over-the-Range...
I have a microwwave oven that turns on but will not heat. It has never worked. Is this an install problem or unit problem? KCMS145JSS
You will need to check to find out if the microwave has all the power coming to the critical units.
If the latch switch is active then the turntable and fan must work but if there is no heat, the check on the thermal cut off switch fitted on the side of the cabin , if faulty. , the pwoerr will be cut off to the magnetron. Check also to confirm that the high voltage capacitor is working and not shorted or open.
The relay on the main boarrd also must click to switch on or else the relay or relay drive must also be checked out.
Aug 27, 2010 | KitchenAid KCMS145J Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Power on Turn,Turn Table Moves,but don't heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Nov 27, 2009 | Maytag Microwave Ovens
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave no heating
It sounds like the magnetron failed.
Check this link for more info and maybe a way for you to test it for functionality. If you are uncertain on what and how to do it, I would suggest to take to a repair tech.
Feb 27, 2008 | Maytag MMV5207A Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Kenmore 80412 Microwave Oven Logo
197 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
