Question about Car Audio & Video
Prower acustic amp in protect mode
I have an power acustic ps2 1800 watt amp and its in protect mode and i'm not sure why or whats wrong
Try diffrent subs if a speaker is blown it may thoe the amp into protect mode
Posted on Sep 11, 2008
  • 41 Answers
1) Make sure the amp is properly connected to +12V power source. 2) Make sure the amp is grounded well, directly to metal - if you have a voltmeter, an easy way to check the first two is to see if there are 12 volts across the power and ground wires. 3) Make sure the speaker output wires aren't touching each other. If none of these are the case, there is an internal problem with the amp and it should be serviced or replaced.
Posted on Sep 21, 2007
  • Chris Allen
    Chris Allen Sep 21, 2007
    Also, what ohm load are you giving the amp? How do you have your speakers/subs wired up?
Can anyone help
What size is the amp and how many watts is the speaker(s) you have it ran too? If your speakers are trying to pull too much power from the amp it will turn itself into protect mode to keep from blowing a fuse as well as if you are pushing to many watts into small small speakers it will do the same to protect from blowing the speakers I would recommend turning the settings on the amp down slightly and then trying it out also make sure your wires arnt crossed adjusting the setting as it plays is the easiest way to fix the problem also make sure the bass isn't all the way up on your head unit
Jul 12, 2013 | Car Audio & Video
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
My Pyramid Arctic Amp 1000 watt was working fine for about a month then one day the protective light came on and stayed on as long as the amp had power. So now it wont give any watts to my two 12's....
Troubleshoot to the component level to find out what is causing protect mode. A short in the output stages as a result of overdriving is one likely suspect.
Jan 14, 2018 | Pyramid PB1615X Car Amp
My boss amp is on protection mode and it wont work its a 3500 watt chaos idk what is wrong with it
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
Dec 25, 2009 | BOSS AUDIO SYSTEMS Music
JVC 600 watt amp overheated
Yes it has a protection mode, let it cool for while then try it again, if it over heats quick make sure you're not running the amp below its stable impedance.
Aug 30, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
406 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
