Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony tv problem
I have a 20" sony wega TV. My girlfriend hit a button and the screen went to static and says "no signal" at bottom od screen. We have Direct TV but it seems to be working fine. It happened when she hit a button on the remote. thanks for the help
  • 398 Answers
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Posted on Sep 18, 2007
SOURCE:
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Jan 10, 2015 | Televison & Video
I did a reset on my Sony WEGA TV but now it's not connect with the cable box. Just says no signal. Screen is all snow and no sound other than static.
you need to reprogram channels. Itll only pick up 3 if you are still using coaxial cable from box, or change input to DVI/HDMI, aux, etc.
Oct 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at [email protected]. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Trinitron WEGA 20" Problem
    change the tact switch of tv/video coz its deficteve.
    Sep 30, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    Screen went BLACK!
    My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
    Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony Wega
    have you tried an external antenna?
    Dec 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    "No Signal"
    Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
    Jul 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony 32" wega tube
    plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
    Apr 01, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
    Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
    161 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
