Question about Sony CDX-L480X CD Player
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm number, just all buttons don't work. Display works ok. I have cleaned front panel connector - still unsuccesful. Its probably ruined already, but there is still hope.
  • tomaszwor Jan 04, 2010
    Good point headgardener. I've tried resetting it after cleaning front panel connector. Still nothing. Probably mechanical/electronic problem with buttons switches. Repair guy changed some suspicious looking buffering diodes, it works now, but sometimes problem comes back.
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Posted on Dec 29, 2009
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Front panel buttons on Philips rear projection do random things
Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
Pete....Digital TV & Radio in NC
May 16, 2009 | Philips 55PP9401 55" Rear Projection...
How do you set the clock on a pioneer KEH-P2030
1) Hold the source button until the radio shuts off.
2) Hold clock button until clock is displayed.
3) Use < and > buttons to move from hours to min.
4) Use volume up and down to adjust time.
5) Press band button when finished.
6) Press source button to turn radio on.
Jan 18, 2009 | Pioneer KEH-P2030 Cassette Player
Pioneer Supertuner IIID
To change the clock on this Pioneer stereo try this.
1. Press and HOLD the source button till the radio shuts off. Release the button.
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing.
3. Press the UP and DOWN buttons to adjust the hours.
4. Press the LEFT or RIGHT arrows to MOVE TO THE MINUTES.
5. Press the UP and DOWN buttons to move the minutes.
6. When complete, press the source button to exit.
Oct 01, 2008 | Pioneer DEH-P690UB CD Player
Won't switch to tuner
Sounds like the source button is not working properly. I have seen this type of problem caused by a crack in the display board. It can also be a bad contact on the source button.
Could be several other things as well, but most of the time it is something like a cracked board.
You can also try resetting the unit, look to see if there is a very small pin hole sized button on the display someplace, if so, use a paperclip or a toothpick, ect. to depress that switch. you might get lucky and the micro just needs to be reset. Sometimes you can reset a unit by disconecting the power wires for a few seconds, or just unplug the harness in the back for a short time.
Hope this helps
Jun 16, 2008 | Pioneer DEH-1300 CD Player
2004 RX8 electric system
The radio screws holding the radio are not tight enough. to eliminate this problem remove the radio and adjust the pressure screw in the rear of the radio so it comes out farther>. if the radio is not far enough in the compartment to push in that button the radio controls will not work
Jun 12, 2008 | 2004 Mazda RX-8
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Time setting
Make sure unit is off by pressing and holding the 'Source' button. Wait 3 seconds, and then press and hold the 'Source' button. Do Not Release the button! A display reading "Initial" will show. Then use the arrow buttons surrounding the 'Source' to set clock. The 'Function' button isn't involved, dispite what the manuel states.
Nov 28, 2007 | Pioneer DEH-P3900MP CD Player
Buttons Don't Work
I would strongly lean towards factory service. Sounds like the circuit board has problems.
Good luck.
Oct 04, 2007 | Grundig YB 400PE AM/FM/SW Radio
Remote or Tuner Problem?
here is a way to see if the remote works on not. get radio and switch it to am mode. then face the remote to the radio and press the buttons. if you hear noises, then the remote is working fine. if not, the you have to open it and clean it from the inside. use alcohol on the board but never put any alcohol on the rubber buttons. just use a q tips to clear the rubber buttons. good luck
Sep 09, 2006 | Kenwood HTB-406 System
Sony CDX-L480X CD Player Logo
497 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
