Question about HP Compaq nc6220 Notebook
Looking for audio driver
Trying to find audio driver for my compaqnc6220
Im haveing audio problem
Check your audio and sound controls in the control panel. Click Start/Control Panel and look for Audio or Sound.
You can also get to the Audio and Sound Properties by clicking on the megaphone at the bottom right near the time.
Try download and installing your audio drivers from your computer manufacturer's website.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Audio drivers.
Try using the VLC Player. It comes with drivers and codec. I've seen it solve many sound and audio issues.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
Jun 04, 2012 | Computers & Internet
I need a conexant audio update
You can click update driver from the device manager. If that don't work click Start/My Computer and look at the folders on your C: Local Drive. A lot of times you might see a folder called SWWetup (Software Setup), look in it and see if the audio driver and application software is in it, if so reinstall it by opening it and clicking on setup. Also you can look for a folder called HP or Hewlett Packardand most times under HP or Hewlett Packard there will be a Driver folder. Look in the driver folder and see if you can see the Audio and run it's setup. If all fails go to google and type "hp support" and look for drivers and downloads. Go the hp's site, key in your model number when asked and the operating system and download and install the audio driver.
Mar 18, 2012 | HP Pavilion dv6000z Notebook
I need AD19818 sound card driver
First, try Windows Update (look for optional updates for hardware). If you don't find it there, check your manufacturer's website support pages. Third, try RealTex's audio codec drivers (note their disclaimer). The fourth-best option is driver-notebook-download.com's Realtek driver page. (I have not verified that site is clean, or that the driver is up to date. Use it at your own risk.)
Nov 12, 2011 | Computers & Internet
My audio driver is not installing from the mother board cd. what to do.
Try to look for other drivers. You can test and download other versions and see if it'll help.
Mar 05, 2011 | Computers & Internet
My M-Audio 410 run well on my XP pc.... after that i try to use it on win7 pc using driver download frm m-audio website but it can't detect. after that i try to test back on my last xp pc but it can't...
HI there
I would imagine the drivers from M-Audio are not signed and therefore may not be proven to be compatible with win7. I checked the website and they have drivers for different service pack levels on Vista (I know yours is win7) which is very unusual. This points to them having issues releasing signed off working drivers. Make sure you know what you have installed, 32 or 64 bit win 7. Do not go by the sticker on the case. Go start>control panel>system and look it up philswift_13.jpg
Both versions of 64 bit and 32 bit seem the same file FireWire_6.0.1_5.10.0.5058.exe
which seems weird too
I would uninstall the drivers and choose delete as well
start>search> type 'dev' and see the results. Click on device manager, open it
under sound right click all devices>properties>click on driver tab>
then click uninstall but tick the delete driver box too
then reboot the pc but do not load the driver from M audio
we want Microsofts generic driver to load
After the reboot see if it works.
If not do a system update (start>search>type 'windows u' and click on windows update
Look under optiopnal updates and see if there is one for an audio device and load that
Failing this try the M audio XP driver
If that fails, uninstall and delete as per earlier.
Failing that try the Win 7 driver for 32 bit
Failing that try the Win 7 driver for 64 bit
I think M audio has issues with code for drivers and win 7
http://www.youtube.com/watch?v=anJJ02VV1qs
You may want to look at a new system as it seems M has some bad press with support.
All the best now, but it may be that the drivers are not signed off from Microsoft. If this is the case, you may want to chase up M audio and ask if they can be honest and let you know if there are any issues with Windows 7.
Microsoft are releasing Service Pack for Win 7 first half of 2011 and this may mop-up some issues. http://windows.microsoft.com/en-GB/windows/downloads/service-packs
Phil
Dec 17, 2010 | M-Audio FireWire 410 External Sound System
Emachines t3304 no audio
try either rolling back in system restore to when it did work or roll back the driver. Also try looking up the driver for your device at a place called drivers.com and then uninstall old driver and install newdriver,hope this helps.
Apr 15, 2009 | E-Machines (308714) Motherboard
Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Jan 24, 2009 | Acer Aspire 3680 Laptop
Realtec audio not working
If you audio driver stops responding, you can try uninstalling the audio driver then restart the computer. First, right-click on the "My Computer" icon and select "Properties". Next, go to the "Hardware" tab and choose "Device Manager". Now you need to look for your audio driver and find the one that lets you uninstall the driver. Do not worry about installing the new driver because the system will find the audio when you reboot your computer which is what you will do after you uninstall the driver. So, reboot and wait. If you audio works you can move on, if it does not work you should go to the Realtec website and look for the most current driver and install that one. This is a start.
Oct 30, 2008 | Computers & Internet
Sound card
Guide to troubleshooting Windows audio and sound problems
>>> Troubleshooting Overview
> Summary of steps that follow
  • Read the "Things to know before you start" section to understand some basics
  • At any point, consider a System Restore especially if your device suddenly disappeared or a driver problem just started occurring
  • Find your audio device(s) in Device Manager
    • If not found, check if onboard audio is disabled in BIOS
    • If found and it has a yellow icon, there's a driver error. Try reinstalling the driver
    • If found but it doesn't appear with a yellow icon, the device driver is working properly
      ==> Check if the device is using a generic driver from Microsoft or using a hardware specific audio driver (you want the hardware specific driver)
      ==> Next, look at the "Automated FixIt Tools and Other Help Guides" section. Try running the Microsoft Automated FixIt tool. If that doesn't help, you can try reinstalling the driver, checking your default playback device is set correctly and/or start looking through the other Help Guides for more help and tips
  • Also, see the "Notes and Tips" section towards bottom of this post for more debugging hints
> If you'd like more help with your specific problem
You need to create your own new topic / thread along with a problem description (see HERE)
  • Include info about: your computer make/model, Windows OS version and of course a problem description. ALSO, if you have an addon sound card include its make/model as well
  • Create your new topic in either the Audio and Video or Device Drivers forum - whichever one you think is suitable to your problem
> Only general comments, general questions, clarifications and corrections, etc. should be posted as replies to this guide
> Windows doesn't need a sound card or audio drivers to generate simple beep tones
Don't assume your audio "worked for a moment" just because you heard beeps (e.g like error beeps)
> Integrated Audio vs. Addon Sound
  • "Integrated" audio is the audio device that comes built into the computer's motherboard. Integrated audio may also be called "onboard" audio.
  • "Addon" sound is an audio device not on the motherboard. For example, if you add a sound card for your machine, it's addon sound. Addon sound may also be called "offboard" sound
> AC'97 vs. High Definition Audio
AC'97 was the first audio standard for computer sound (It was created by Intel in 1997). AC97 audio was superceded by High Definition Audio (also called HD audio) in 2004. It often helps to know whether your audio device is AC97 or HD Audio
  • All newer soundcards/audio devices are HD Audio. (I'd guess all audio/sound cards built since at least 2007)
  • Look at the audio device name in Device Manager
    ==> Names for HD Audio devices always include words like HD or High Definition within the name. Examples
    • Computer 1 on the left: Computer 1 has two audio devices (fyi: Computer 1 happens to have two sound cards: It has both integrated audio plus an add-on sound card). Look at the device names. You can tell from the names that both devices are HD Audio
    • Computer 2 on the right: Computer 2 only has one audio device. Look at its device name. You can tell from its name it's not HD Audio therefore you know it must be AC97)
> Generic vs. Hardware Specific Drivers
Microsoft provides generic audio drivers in Vista and Windows 7. If Windows can't find a hardware specific driver for audio, it may load its own generic driver. The Microsoft generic driver usually doesn't provide fully functional sound (and, often, microphones won't work with the Windows generic driver)
To see which driver an audio device is using
Open Device Manager, rt click the audio device, select Properties
..> If there's no Driver tab or the Driver tab shows Unknown, no audio driver is installed
..> If the Driver tab shows Microsoft, the audio device is using the generic driver
>>> Troubleshooting: First steps
> System Restore
At any point, consider a System Restore especially if your device suddenly disappeared or a driver problem just started occurring. System Restore will inform you if the restore attempt was successful or not. System Restore doesn't affect your personal folders and data
==> How to Restore a Windows XP system to a previous State using System Restore
==> Using Windows 7 or Vista System Restore
> Verify your audio device is detected
Check Device Manager. Can you find your audio device(s) listed? Does it appear with any special icons?
Device Manager icons
==> Yellow icons with a black exclamation point indicate a driver problem
==> A "down arrow" indicates a disabled device in Vista and Windows 7
==> XP uses a yellow icon with a red X for disabled devices
To check Device Status
==> Rt click the device, select Properties. Check Device Status on the General tab. Is Device Status = "This device is working properly"? Or is there an error code number?
==> If Device Manager says it's "Working properly" yet you still have sound problems, suggest you next see the "Automated FixIt Tools and Other Help Guides" section below. Run the Microsoft Fixit tool for Sound. If that still doesn't work, try a reinstall and look through the other help guides listed below. Also check your default Playback device setting (see "Notes and Tips" below)
When looking for your audio devices in Device Manager
  • First, look for your audio devices under Sound, video and game controllers
  • Next, see if you have an Other devices category. If the category exists, check each it lists
    When Windows can't identify a device, it gets lised under under "Other devices". "Other devices" are also called "unidentified devices" "Other devices" often appear with generic names. Example
    ==> On left: "Multimedia Audio controller" is a generic name for an unidentified AC97 audio device
    ==> On right: "Audio Device on High Definition Bus" is a generic name for an unidentified HD Audio device
  • If you can't find your audio device listed in Device Manager, reboot and look a second time. If you still can't find it
    ==> Note if you're still running XP SP2 you need this MS KB installed for HD Audio support. (XP SP3 and all versions of Vista and Windows 7 already include HD Audio support.)
    ==> Check if your audio is disabled in BIOS. Look for a BIOS setting named something like Onboard Audio orIntegrated Audio
    • If you find it, it should be set to ON or ENABLED or something similar
    • Not all BIOS provide this setting. Tho also be sure to search through all the BIOS menus to look for it
    • For more about how to enter BIOS menu setup see HERE. You can also check your system/motherboard provider's Support site for their documentation
> Reinstall the audio driver
Different methods of reinstalling are listed below. If the first two don't help, find the driver on the vendor site, download and install it yourself. If the driver installation seems problematic or the old driver installation seems to interfere, check if you have the option to first uninstall the current driver installation yourself from Add/Remove Programs
  1. Reinstall using Device Manager
    > Rt click the device, select Uninstall. Reboot. Windows should redetect and reinstall the device on startup
  2. Let Windows search for an updated driver
    > Rt click the device, select Update Driver. Follow the prompts. Allow Windows to search the internet for an updated driver
  3. Check if the audio driver is listed in Add/Remove Programs. If it's listed, uninstall it
    For XP, look in Ctl Pnl->Add/Remove Programs. For Vista and Win7, Ctl Pnl->Progams and Features
    Here's why: Some audio driver installers create an Add/Remove Program entry for the driver. (It's entirely up to the vendor and how they chose to write their driver so you may or may not find an Add/Remove entry)
    • When you uninstall using Device Manager, driver software is uninstalled but it's not deleted UNLESS Device Manager specifically offers you a delete option. This is also why Windows can reinstall a device on reboot when driver software is uninstalled (but not deleted)
    • "In theory" a new or updated driver should uninstall and delete old driver files itself when it runs but this isn't always the case. It never hurts (and sometimes helps!) to run the Add/Program uninstaller yourself if you find one
  1. Find an updated driver manually
    > Create a System Restore point before trying to install the new driver
    > Check vendor sites for their Support or Download link. Do an internet search or look at the topic HERE for links to many vendor sites
    • If you bought a complete PC system (e.g. from Dell, HP, Sony, ASUS), check the PC system provider first
    • If you bought an addon sound card, check the addon sound card provider
    • If you bought your own motherboard, check the motherboard provider
    • Check the audio chip provider on your soundcard. When looking for drivers based on the audio chipset note
      ==> Audio providers (like Realtek and IDT Soundmax) often provide both the audio chipset and the driver. While general chip makers (like Intel, SiS, and Via) usually provide just the chips. They rely on (and will point you to) someone else's driver that works with their audio chips (such as drivers from Realtek or IDT Soundmax)
  2. Find an updated driver using DriverEasy
    > "If it ain't broke, don't fix it". Only install DriverEasy's audio driver updates
    ==> DriverEasy returns every driver update it finds including "beta" (pre-release versions). Newer is not always better. Only update the driver if the device isn't working
good luck
Jan 13, 2008 | Acer AOpen AW 37 Sound Card
HP Compaq nc6220 Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
