Question about HP Computers & Internet
Don't understand how to burn DVD's
Ok, so I have been trying out my laptop for burning dvds but i am still a lil lost. I started out using the pre-installed program "windows dvd maker" and another one "windows movie maker" and when I would try to bring and burn files to it, it would only allow still pictures and not any of my lil video clips that I have saved in "my pictures". I am still xo confused and would really love some help and guidance on how to do this. thank you
Inspiron 1525 PC Notebook: can i use Dell Inspiron 1525 to burn dvds? How to ...
Hi Richard, yes you can burn DVDs with your laptop. Check the CD/DVD disc that came with your computer. However, I understand its pre-installed either with Roxio or Sonic utilities. On the other hand, if you have Vista and Windows 7 it will do as well.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
May 18, 2010 | Dell Inspiron 1525 Notebook
Toshiba Tecra A4 version 1.70 has 'lost' 'Sonic' from 'all programs' so Now I can't burn DVDs.
I hope you made your restore disks for your laptop when you got it... You need to reload Sonic...
Apr 13, 2009 | Toshiba Tecra A4 Notebook
Not able to burn dvds from file
if your DVD Drive ( ROM ) read-Only-Memory. then it will only read DVDs And Not Write Them. You need a DVD RW Drive, to be able to write. If Your CD Drive Is A CD/RW That means its a CD Re-writable drive. try a Burn To CD.
Mike @ Compurepair.
Mar 26, 2009 | Computers & Internet
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
My dvd burner doesn't burn dvds
You need to check that with blank DVD's you are using compatible with your drive.Because the DVD's may work with your extranal drive but not with your builting drive. If this doen't slove the problem I would recommend using a different burning software other than "sonic record now" and "vista o/s Built-in dvd burner".
Sep 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Cd burn
Either the drive is bad or your using the wrong type of blank dvds.Try using DVD-R or DVD-RW for betters chances of success.Sometimes some of the new DVDs are bad.Make sure you try a couple different ones even from a new pack of DVDs.
Jul 22, 2008 | Toshiba Satellite A105-S2716 Notebook
Reads and writes cds,reads dvds but does not burn dvds,
This drive is normally supplied with a couple of Dells.
(because of compatibility) Inspiron 700m,710m
If you have another machine for testing?
check the disk for contents to see if the data burn happened,
this will explain a few things in your processes.
Uninstall/Reinstall the drive and reboot then try again.
Have you tried a full system reinstall yet?
Did it fix your problem?Please let me know thanks
Jul 15, 2008 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
DVD / CD - RW Combo
When you say you cannot burn DVD's, do you mean you cannot burn DVD movies or do you mean you cannot burn data files to a DVD?
Burning DVD movies requires specific software to transcode the video and create a directory structure that DVD's players expect.
When you try to burn DVD's does it produce an error? What software are you using to burn?
Nov 19, 2007 | Acer Aspire 3680 Laptop
Can't burn DVDs (VistaHomePrem)
Well I am not surprised ya can't get it to work.. It can all be quite confusing.... I suggest that you try some "Other" burning software. I recommend CopytoDVD...AnyDVD ... convertXtoDVD.... vso-copytodvd.en.softonic.com/ OR AnyDVD www.slysoft.com/en/download.html ConvertXtoDVD vso-convertxtodvd.en.softonic.com See one has to have a program that will "Burn" in a Format suitable for ALL players PC & stand alone DVD's the ones I have listed Just work... ensure you read the "Help" files and B4 long ya will be watching DVD's.
Sep 05, 2007 | Toshiba Satellite P105-S6207 Laptop
DVD drive not recognized as RW
If you use the Nero Smart start, you should see an icon to switch from burning CDs to burning DVDs. Once you click this icon, you should be able to burn to DVDs. Step-by-Step tuturials can be found for nero products here" Nero 7 http://ww2.nero.com/nero7/enu/Tutorials.html Nero 6 http://ww2.nero.com/nero6/enu/Tech_Support.html
Sep 16, 2006 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
