Question about Canon GL2 Mini DV Digital Camcorder
Canon Gl2 Artifacts and striping on the tape in playback. My canera have recently had problems when recording. I have never cleaned the heads, Could this be the problem? How do I clean them?
  • Anonymous Feb 24, 2009
    I have a canon gl2 that is jammed. the video doesn't eject, nor does it have any motor functions at all. the rest of the camcorder seems to work fine, but the mini-dv tape mechanism is screwed. i sent it to canon once and they did a rush repair job on it. a tensioning arm was loose when they sent it back and it wouldn't record right. it fell out when I looked in the machine to see if I could find the problem. I put it back where it belonged and the camcorder began recording and performing beautifully. just 2 days ago I inserted a brand new tape and it seized up and now i'm without a camcorder for my documentary project.
Do you have to playback for 5 minutes each time eject and playback?
Posted on Dec 13, 2007
  • C-dubz Dec 14, 2007
    yes u do ...Nevermind..but for any1 else U do that On the 5th time Ull see it start working
Do u have to playback wait 5 mins. Then eject each of the 5 times
    Champion:
  • 217 Answers
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 18, 2007
Blue screen no playback with tape glitching canon gl1
Have the previous owner demonstrate that it is fully functional.
Jan 08, 2018 | Canon GL1 Mini DV Digital Camcorder
Camera gl1 is recording glitches on the playback
go at the electronic store, buy head cleaner and vcr head cleaning tip cleaner, then clean the head with this stuff manually... Head are fragile, so you might make it clean at your local vcr repair place...
Aug 07, 2009 | Sakar (CNGL2CHLENS) for Canon GL1, GL2,...
Thick stripes on the recording on mini dv tapes
Stripes are either caused by -
Bad tape - try a new tape
Dirty tape head - can it be cleaned? Cotton wool bud and some metho?
Electronic fault.
Try a different tape first.
If that doesn't help, clean the head. Is it under warranty?
Apr 25, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Lines on playback
You were practicing what consumer shoud do to clean video heads. If you were using the tape too many times, it may wear the head down quickly. First remedy would be let a professional technician clean the head for you to make sure it is not heavy clogging of the head. If that did not work, it requires tracking system adjusted and aligned before the video heads is replaced. I hope the cleaning by a technician takes care the problem. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
Apr 05, 2009 | Canon GL2 Mini DV Digital Camcorder
GL2 Tape comes out pixalized
You may have a heavy clogging of the heads. The head cleaning tape will not serve in this situation but manual head cleaing from trained technician. Head cleaning service shoud go around $100. Same symptom would happen when the tracking goes off on GL2 and this may cost more to adjust. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 31, 2009 | Canon GL2 Mini DV Digital Camcorder
Audio is cutting out on playback
You did every thing right. Audio is effected by clogged video heads and the audio circuit. At this time, you might look at the service by professionals. 50% chance the audio problem could be resolved by cleaning video heads and tape path without much adjustment, you cost would be around $100-150. If this does not resolve the issuie, Camcorder need repair and would run $250-400 for GL2 model. Good luck. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 27, 2009 | Canon GL2 Mini DV Digital Camcorder
My canon gl2 won't record because it keep telling me to eject the tape. I put in a new tape and the samething keeps on happening. What can I do about it?
You may be the victim of dirty clogged head. When the tape is incerted on GL2, it is searching for the data from the tape but if the heads are clogged it will not communicate so, the processing computer think the tape is damaged. Procedure to clean the head. This may not clean but let's try. Purchase a head cleaner tape and run it for about 10 seconds but not more. Try to insert regular clean tape and try it. If this does not resolve the problem, GL2 need cleaning and adjustment by technician. Good luck -James. For further assistance email, go to www.camerarepairjapan.com
Mar 23, 2009 | Canon GL2 Mini DV Digital Camcorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Jan 26, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
542 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
