Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Colours red and green are out of sync
Hello .. i hope you can help .. our tv has suddenly developed red and green halos on the picture .. i followed the instructions for multipoint cong. but some of the red crosses are lop sided. and im not sure if they can be straightened . The bottom lot of x's is forming like an arch on the bottom of the screen (these are red) .. do i just keep trying to connect the crosses together or is there something else i should be doing
  • Philips Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
colours red and green are out of sync - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
The colour has suddenly developed a green tint to the picture which I am unable to adjust The model is LE37R87BD
A green tint to a tv means it's lost its red channel (may additionally be blue channel). Check that your video cables are connected fully. If that's not the culprit, and changing tv settings doesn't work, you'll need to take it to a repair shop; so they can repair the "red circuits:" Note: there aren't any "red circuits" per 'se, but there are circuits that tell the various computer chips - in the tv - how to handle the image. By "red circuits" I'm referring to these.
Sep 05, 2010 | Televison & Video
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Colours are getting out of sync, picture distortion
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 29, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Colour split green and red with shadow effect on a Samsung rear projector 42" TV
HELLO. IT SOUND'S LIKE YOUR PROBLEM IS IN YOUR CONVERGCE BOARD.!!! YOU MAY HAVE TO REPLACE YOUR (IC chip's) on the board .!!! they are what control the color for your convergence.!!! set up .!!! that make your (CRT GUN'S) BLUE & RED LINE UP WITH YOUR GREEN (CTR GUN) TO MAKE YOUR PICTURE LINE UP RIGHT.!!! HOPE THIS HELP'S YOU .!!! "GOOD LUCK"
Aug 10, 2008 | Televison & Video
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
