Question about BonJour BJ11300 Wine Cooler
I have a bonjour wine cube deluxe and its not cooling
Everything works fan comes on just not cooling its blowing hot air
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
FRIDGE FAN DOES NOT COME ON
What is the cooling problem? Have you checked the fan after holding in the light / fan switch. Some fans go off when the door is open. Fan is probably stuck due to lack of lubrication. Check fan to see if it spins freely. UNPLUG UNIT BEFORE EXPOSING WIRES, be sure you are clear before plugging in while doing test runs etc.
Jun 27, 2009 | BonJour 53372 Wine Cube Refrigerator
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
My blower motor doesn't blow air out the air ducts why
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Bonjour wine cube #53372
The Bonjour Wine Cube Is NOT a refrigerator it has no freon it circulates air to keep wine stored at proper temperature for cellar. To chill place in fridge or get something with freon.
Nov 10, 2007 | Refrigerators
BonJour BJ11300 Wine Cooler Logo
167 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
