Question about Canon PowerShot A720 IS Digital Camera
MY CAMERA SHOWS MEMORY CARD ERROR MESSAGE WHEN TURN ON AND IS NOT RECIGNIAED BY THE COMPUTER AND I CANNOT FORMAT IT BECAUSE IT CONTIAN MY WEDDINDG PHOTOS SO PLEASE POST ME SOME SOLUTION early
  • Canon Master
  • 13,433 Answers
TAKE THE CARD TO A CAMERA SHOP WHERE THEY CAN RECOVER THE PICTURES FOR YOU. CALL IN ADVANCE TO CHECK IF THEY CAN RECOVER PICTURES FROM A CARD.
OR YOU CAN TRY TO RECOVER THE PICTURES AT HOME IF YOUR SMART. USE THIS TOOL http://www.quetek.com/prod02.htm
SEE IF YOU CAN RECOVER THE PICTURES FROM THE CARD WHEN YOU CONNECT IT TO YOUR COMPUTER WITH A MEMORY CARD READER.
Posted on Apr 18, 2009
I get a memory card error message on my Pentax Optio S40. I bought two new memory cards. Sandisk 512 mb. I get the same message on them. I tried formating the card on my computer. When I pit it in my...
Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
Jun 02, 2011 | Pentax Optio S40 Digital Camera
I get an error message on my display showing "cha". When I looked it up in the manual, it says that the card isn't formatted correctly. I bought a brand new card for it, but the same message...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 07, 2011 | Nikon D50 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
SD card - memeory card parameter error
Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Dec 23, 2007 | Samsung S850 Digital Camera
Memory card
is it for a camera or a phone because if it is for a camera you have to format the memory card by the camera itself you cannot format the data or etc on the computer
Sep 26, 2007 | Samsung Digimax S630 Digital Camera
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
