Cannot complete installation
Halfway through the installation, a box pops up with "path cannot be found". I have tried different options to no avail. Thanks.
  • 1 more comment
  • david parker May 11, 2010
    installation of what? and on what?
  • mrninja
    mrninja May 11, 2010
    what are you trying to install?
  • ultimitloozr May 11, 2010
    What are you trying to install? What path is it looking for? (It should tell you in the error message.) What operating system are you using? (Include 64-bit or 32-bit if XP Pro or Vista.)
    President:
  • 987 Answers
Your installtion files might been corrupted..
Posted on May 29, 2009
I want install a pendrive on my router, i can see my pendrive on the router settings but cannot see it in my desktop
In the router settings, you should see a tab or a drop down menu for usb storage or something like that. once you set that up, you should be able to map your pen drive to your computer.
To map it,
click start>computer
up top you'll see "Map Network Drive" click that.
A box will pop up and it will give you an option to assign a Drive Letter. it doesn't matter what you select.
In the folder box, you'll want to put in the path for your pen drive..my router network drive looks like this...yours might be different, but it's pretty much the same setup....
\\Readyshare\USB_STORAGE\
To find the correct path for your pen drive, you'll have to go into your router settings and where you set up the pen drive, it should tell you the path....just copy it and past it in the folder box.
Be sure to check the box for Reconnect at logon also.
If you still need help, let me know the make and model of your router and i can be more specific:)
Gary
Sep 16, 2013 | Computers & Internet
I cannot open iPhoto
You could try iphoto library manager available from http://www.fatcatsoftware.com/iplm/ you can try before you buy and it may repair the iphoto library. Hope this helps.
Sep 12, 2012 | Apple MacBook Air
HP Digital Media Archive Pop UP
The setup file was stored on a network, it wasn't on your computer and now its trying to get it and it can't find it. you will have to get a copy of the file to your computer and then when it asks or the pop up comes you need to direct it to the file you got.
Mar 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Reinstall Sonic MyDVD from the Application Recovery. A lot of HP computers have done this or produced that constant pop up.
If that doesn't work, go to:
Start > Run and type in msconfig in the box.
Then click the Startup tab and uncheck the box beside DMA (digital media archive)
Click Apply then Close. Reboot when prompted and you shouldn't get that annoying pop up any longer.
If you don't even use the Sonic MyDvD program on the computer, just uninstall Sonic completely from Add/Remove.
Mar 09, 2009 | HP Pavilion Media Center TV m7680n PC PC...
me aparece una ventana dificil de serrar pidiendome el archivo ezarc.msi
Aug 25, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Sounds like you have may have it run on startup. Just to see you can use msconfig to temporarily disable it by following these steps:
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information.
Thanks
Aug 08, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Help... 1640n
Here's what HP has to say about your error...It appears to be an issue with Sonic MyDVD. Reinstallation of the program seems to be the solution.
Jul 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
well guyz... i got a solution... while u get the pop-up... open the task manager... and then search for the process DMASCHEDULAR
and end the process... it worked for me...
Feb 09, 2007 | HP Pavilion a1410n (ER890AA) PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
