Question about Toshiba Satellite M35X-S161 Notebook
Matsushita/Panasonic udja 760 cd/dvd combo won't read disc type or file system - sees and plays CD but not DVD (drive light blinks while loading and then stays on as if playing but XP and Cyberlink show "no disk"). Removed all Roxio and Sonic - upper and lower filters - PIO to DMA and cleaned lens - STUMPED!!!
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    how u cleaned lens like this if not try this
    open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements and this MATSHITA Drives are No : 1 in fault i have experienced personally thats why all vendors HP , Acer, and Dell all have switched to other brands as OPTIARC , NEC , TOSHIBA they are good if u compare them
    u can find one on ebay cheap just look out for the bezel and size is always universal typebut u need to put ur original bezel on it it can come out easily ask me for tutorial if u want
    if u go to OEM like HP or Toshiba they will charge u double!
Need a driver for matsushita ujda710 cd
just type your model no and brand no in the google search engine then you will get too much link and also get driver from here. thanks
Nov 05, 2012 | Panasonic Ujda710 Combo Drive. 8x Dvd-rom...
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
My dvd cd rom rw won't play- the light turns on when disc inserted and goes off, my system says player working?
Try this...
Press widnows(log)key+R
Type devmgmt.msc and press enter
Cilck on '+' beside CD/DVD rom
Right click on listed drive and select Uninstall.
Go to Action tab and select Scan for Hardware Changes.
Next...
Open a Notepad file, paste the following entries in that file. Starting from "REGEDIT4 till end". Now save the file as cddvdfix.reg.
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
"UpperFilters"=-
"LowerFilters"=-
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdr4_2K]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdralw2k]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdudf]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UdfReadr]
Double clik on the saved file and run it. Restart, Drive will start working.... if not, then the drive gone bad
Sep 28, 2010 | Philips CDD5101 CD-RW/DVD-ROM (Combo)...
NEW gcc-h23n will not read anything
If not reading DVD is a pattern (it won;t read ANY DVD, no matter if it's a burned one or an original movie) then the lens is dead. I'm afraid you'll have to go get a new one (new drives are very cheap, usually around 25-30$)
Apr 30, 2009 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Do not read the cd or dvd disc.
Its zamzam,i wud suggest you buy a new one from a better manufactuerer.
Aug 19, 2008 | Computers & Internet
My SONY DVD RW ROM is not reading any DVD
Installing a third-party image editor or viewer applications may sometimes hijack the image file associations. In such circumstances, you could use this utility to repair the file associations (following image file types) to Windows XP defaults.
Click on Download utility and Click on RUN and then once again RUN
Check All the files and then click on Repair Associations
Download Utility
For the CD DVD Issue
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 12, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
LG CD/DVD combo does not recognize virgin DVD´s
DVD combo do not burn DVD's they can only read DVD read CD and burn CD to burn on a dvd you need a dvd writer. A DVD combo is a combination of just a DVD ROM and a CD-RW.
with some models (even of LG) you only get one drive DVD/CD-RW but in dome version it shows as two different drives DVD and CD-RW. consider this as partioning of a drive if its to be analogued to HDD (though its not partioning its just diffrent PROMS)
Hope you understand that there is nothing wrong with your combo its just that you are expecting it to be a DVD-RAM which it is not.
Mar 25, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
DVD/CD ROM drive issue
sometimes these things got dust as dvd writer use 2 kind of lenses. and as u didnt use the DVD for long time may be you need a CD/DVD cleaner disc. which will fix your problem.
Jan 05, 2008 | Panasonic Combo Drive - DVD-ROM & CD-R/RW...
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
DVD/CDRW drive not recognising any DVD's
Hi people!!
This fixed my problem. Give it a go, I have access and am using my burner once more.
Good luck!!
Alex
Note: The solution provided requires editing of the registry.
  1. To begin the process, start the Registry Editor.
    • Click Start, click Run, type regedit, and then click OK.
    • On Vista machines, Run is accessible through Accessories.
    • Click the plus sign (+) next to the following folders in the left side of the window pane:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  2. Look for any of the following names in the right side of the window pane:
    • UpperFilters
    • LowerFilters
  3. If any of the items above are listed, right-click on the item and select Delete.
  4. Be sure to restart your computer after you have deleted the files in the registry.
  5. Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
  6. In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Mar 13, 2007 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
Toshiba Satellite M35X-S161 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
