Question about Kenmore 80412 Microwave Oven
Microwave does not heat
The lights comes on, the plate turns and the fan comes on as well. It just won't heat any food
  • 3 more comments
  • Cency Nov 02, 2007
    i have a kenmore microwave model # 721.63259301, the problem is it just stop heating food. you can see it working but it just won't heat food. can you tell me any troubleshooting i can work on.
  • Anonymous May 13, 2008
    same problem. how do i fix?
  • Toy_Man May 19, 2008
    Kenmore Microwave stock no. 86951, model 564.8698510.
    Power comes on. Timer works, but no heat is generated.
  • Anonymous Feb 24, 2009
    bull
  • stachowiakl Mar 03, 2009
    I have model 721.632252, the turntable turns, it says working at 100% power but will not heat.
    Lucile Stachowiak
    [email protected]
  • 67 Answers
2 problem magnitron or high voltage capacitors one of this bad
Posted on Sep 19, 2007
Try unplugging the unit and do not enter the time of day, just hit clear. Place a cup of water in a microwave approved container and see if the unit heats. I have the samr problem.
Posted on Jan 29, 2008
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9173 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Posted on Mar 20, 2007
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
My microwave won't heat anything up. The light comes on, the plate turns round and it makes all the right noises but it doesn't heat anything up.
Since the light and fan work the main board or the processor is working .Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
As there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Sep 17, 2011 | Belling Microwave Ovens
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Kenmore 80412 Microwave Oven Logo
1,354 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
