Cd stuck in compter and cant eject manually despite paper clip method. this packard bell computer
I have a cd stuck in my computer. i have tried the paper clip thing but still cant eject. iam thinking of opening the cpu and pulling the cd out but dont know where to start from. what shuold i do?
    Brigadier General:
  • 7,191 Answers
Try restarting the computer, and insert the paperclip while the LED light flashes in your CD drive when the computer restarts..
Posted on Apr 18, 2009
A CD got stuck in my Cambridge Soundworks 765i. How do I get it out?
There should be a small hole in the front of your CD player. Straighten out a paper clip, and poke it in that hole. That should eject the CD drawer.
Jan 08, 2016 | Cambridge Soundworks Audio Players &...
HOW DO I OPEN THE CD DRIVE
Hello. The stuck cd drive door. Bin there before. Use a paper clip, bend out one of the arms of the paper clip. Look for a tinny sized pin hole on the cd drive door. Use the paper clip as a push key. Put the paper clip leg in to the hole, lightly push in and pull the cd drive door lightly toward you. Then you can take out the cd and push to closed the door. Then you can use the computer as before. But remember to keep the paper clip as your emergency key. Good Luck.
Jun 03, 2014 | Packard Bell Computers & Internet
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
Cannot get disc to eject
There's a small hole on the front of the drive. This is to insert something like a straightend paper clip into. This is the way in which you can manually open the drive.
Try it, but do not force it open. When the drive is slightly open, you can pull it fully open by hand to remove the disk.
Regards,
Bob
May 20, 2010 | Packard Bell GCD-R580B (gcdr580b) Internal...
How do i eject a stuck cd from gateway one 710 series I have tried the eject button on the keyboard but will not give it up...
Have you tried the eject button from the tray? If all that you need is a tool to eject the tray without touching the tower, I suggest you to go to this link and download the Eject-CD freeware runtime file EjectCD.exe - approx 30kB. Alternative if your tray is locked and can not open with the above methods, you have to locate a small hole in the front panel of the tray and put into that hole something like a connector (for papers) or a strong wire in order to push the internal system to open.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
CD wont eject from drive
Have you already tried to mannually open the tray, by inserting a thin straight object (like a unbent paper clip) in the manual eject hole on the optical disk drive? The hole exists for that pupose.
Jul 18, 2009 | Dell Studio 15 Laptop
Disc stuck
The problem seems to be with your Drive. Just try and remove it out from your machine and then open it up.
If it is still under warranty i suggest you take it to them for a new one, or you can aswell try the paper clip trick but now instead get a longer thin metal pin type of object that will get in more.
Then try and remove the CD out with a supporting Screwdriver incase you need to pull it out.
May 26, 2009 | Dell Studio 15 Laptop
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
