Question about Logitech Driving Force GT Wheel for Playstation 2, PlayStation3
PS3 stopped calibrating with Logitech Driving Force GT
While my PS3 was working fine with Logitech Driving Force Pro, suddenly the wheel failed to calibrate. I bought the Logitech Driving Force GT (thought the Pro was somehow broken). Still the same. Whatever I did, shut down PS3, erased GT5 progress etc) nothing worked. Any ideas?
SOURCE: logitech Driving Force GT wheel won't work at all
It only works if it you plug it in after starting the game
Posted on Dec 28, 2008
SOURCE: force gt wheel doesnt steer, everything else works fine?
The wheel should be plugged in and powered up before turning on the PS3. While booting the wheel should go through its full range of motion and the horn button light will stop blinking and stay on steady. If the light doesn't stop blinking the wheel failed to calibrate and is probably defective. I had to exchange mine and did end up getting one that worked this time.
Posted on Jan 11, 2009
0RazR0
  • 100 Answers
SOURCE: need to calibrate my control for combat arms
Bad news. You cannot use gamepad in this game. I have spent 5 hours researching on this topic. I have even made a gamepad profile for all logitech gamepads. Visit this link and you will get all the info. You can download the profile I have made, its with instructions
http://forums.logitech.com/logitech/board/message?board.id=pcgaming&thread.id=1754
Posted on Jul 24, 2009
SOURCE: cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Posted on Jul 26, 2009
ani24das
  • 89 Answers
SOURCE: reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Posted on Feb 08, 2010
Hi...I just bought the Logitech Driving Force GT steering wheel and pedals...the pedals work fine, the buttons ON the steering wheel work fine...but the actual steering part DOES NOT work..so I can...
-Check if the connections are plugged in properly -Does the wheel calibrate (turn left and right and then centres) when you turn on the wheel. -Doe the game support the wheel? - Plug the DFGT into the USB port 1 of the console AFTER you turn on the console. So turn on the console and then plug in the DFGT into the USB port 1 and turn it on.
ALSO if you are using the DFGT for pc, make sure you install the "Logitech Gaming Software" from the logitech website =
Sep 25, 2010 | Logitech Driving Force GT Wheel for...
Driving force gt broken ?
Check if you have configured the settings properly and also check if the device was installed correctly
Oct 03, 2009 | Logitech Driving Force GT Wheel for...
I am looking for install disc/manual for Driving Force EX for PS3 !!!!!. Can anyone help ??, thanks
ex and the driving force pro and the same wheel buttons are arranged differenly..
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=Xdc1TtDj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=3590&p_created=1145051644&p_olh=0
if you want to know if the wheel is working just plug it into a pc. go to control panel>game controller >properties, and test it there. if it works there it will work on the playstation.
Jul 22, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Need manual for driving force gt
    Please download the manual link given below
http://www.generalmanual.com/Gaming/Logitech-963293-0403-Driving-Force-Pro-Racing-Wheel.htm
Thanks for using fixya.
Jun 01, 2009 | Logitech Driving Force GT Wheel for...
Driving force pro wont work on my ps3
The correct voltage output on the power supply is 24 volts and .75 amps. Center positive outside sleeve negative. Hope this helps.
Mar 09, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Logitech Driving Force GT wheel won't work at all
Ive had this problem yesterday. Confirmed.
Call them to have words. Have respect and they refund you full.
Towards the G25.
I did that. Cause if I broke 1 DFGT then I will break more.
I think that the G25 withstands even drifters technique.
See you on PS3 Tag: DriftMagnet
Logitech Tech Support. Call 1-646-454-3200
Jan 10, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Force gt wheel doesnt steer, everything else works fine?
Jan 10, 2009 | Logitech Driving Force GT Wheel for...
Dec 28, 2008 | Logitech Driving Force GT Wheel for...
PS3 does not recognise the Logitech Driving Force Pro Wheel
hapened to me with a usb drive plug it in,plug it out,plug it back in and leave it for about 10 mins and it should work...thats what i do when my usbdrive dont work
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Logitech Driving Force GT Wheel  for Playstation 2, PlayStation3 Logo
1,754 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
