FixYa.com
Tags:
GE 25GT270 TV
Ticking sound
posted by ke4vbg on Sep 18, 2007
Tv blew fuse, I replaced fuse and it blew again. I determined that the Hor.Output transistor was bad, replaced it and now it tries to turn on, high voltage crackles some if I put my hand on the front of screen but it will not light up. I Hear a ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 18, 2007
Not Rated (0)
modern
Rank:Wiz Wiz
Rating: 79%, 504 votes
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage .
if eht voltage is ok
1 check filament is glowing or not if it is ok check voltages on crt.
2 if it is ok check luminance section in chroma section.
if filament is not glowing check for low eht due to hor section
check power supply output also.
good luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Standard Televisions problems?
Tuning and Storing Channels
Hi there I have a Sanyo... Answer This...
Panansonic TV problem
no picture but sound. picture... Answer This...
jvc information
i cant turn on tv but the on... Answer This...
GE 25GT270 TV
power failure
my clients tv goes off when... Answer This...
GE 25GT270 TV
Can't find headphone jacks or...
Sounds a little silly, I know,... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
