Question about Performance Teknique ICBM-772 Car Audio Amplifier
Sub amp not working anymore
All of a sudden my subs started working and i did not get to check it out until the next morning, i replaced both fuses in the engine but the amp still did not work, as i was looking at it it turned on for 15 seconds then shut off i started checking all connections when inoticed the ground terminal was partially melted and the end of the ground wire was now black, the amp diagnostic light is on and goes of when i disconnect the negative input.
    Scholar:
  • 98 Answers
Sounds like a typical case of poor conections causing the amp to fail... take the cover off of the amp. Inspect where the terminal blocks meet the circuit board. SOmetimes you can repair it sometimes its just too far fried..
Posted on Sep 18, 2007
I have a jl audio 12 w7-3 sub and it just stopped working and wont work anymore,what could it be?
Check your fuses on your amp power lead and amp or make sure your amp is turning on the should be a light somewhere amps can break more times then the sub. Check all your connections or check your amp and head unit settings most probably a fuse mine blow sometimes
Jul 26, 2014 | Car Audio & Video
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
I have a Pioneer 5400t amp hooked up to a 10" 400w sub of unknown brand. The system was working perfectly for about a week, then I noticed the sub wasnt working. I blew both 30a fuses on the amp. I...
Your best bet is to buy a cap. A capacitor is an external battery booster like device. It boost power to amp. The thicker the wire the better. Power and ground. Shorter thicker ground wire the better. Make sure it is not on a painted surface. Scrape down to metal surface!!!!
Nov 12, 2009 | Cars & Trucks
Subs cut out
although an odd thing to have happen it does sound like you blew your amp. check the fuses in it to see if you can avoid having to replace the amp and instead replace a few dollar fuse also check the fuses where you had this pluged in. hope this helps a little. if you give the amp type i may be able to help a little more
Aug 06, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Pioneer AVIC-D3 Audio Problems
Sounds like a problem with the sound chip in the stereo. Disconnect the rca cables from the subs and check to see if the audio returns. If so. try using a different rca connection in the back. Also i think on them radio's if there is a built in sub drive you need to turn that off if you are using a amp to run the subs.
Sep 13, 2008 | Pioneer AVIC-D3 Car DVD Player
Phoenix Gold Xenon 1200 mono not pushing subs and making noise.
This sounds like a problem with the head unit output to the sub amp. Are you using a Pioneer head unit? If so, you may have a problem with some surface mounted fuses inside the radio on the main board. Certain Pioneer head units have a common problem with these fuses blowing. They are fuses for the ground on the RCA outputs.
Let me know if this is the case, and if it is I can give you the part number of these fuses and tell you where they are located, but you would need good soldering skills to replace them. Also let me know what model number your head unit is.
Thanks,
Dave
Sep 08, 2008 | Car Audio & Video
Performance Teknique ICBM-772 Car Audio Amplifier Logo
163 people viewed this question
Top Performance Teknique Car Audio & Video Experts
Mike Duncan
Mike Duncan
Jose Velazquez
Jose Velazquez
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
