Question about GE Profile PSS26NGS Side by Side Refrigerator
Refrigerator stopped working / only makes a dull clicking noise
My 4 year old GE profile refigerator stopped working yesterday. I removed the back and made sure the coils were clean. Unplugged it and pluged it back in. At one point it started up but for less than a minute. Since then I have unplugged it again this time for a half hour. When plugged back in all I get is a quiet hum with a steady dull click/tick noise. No other noises and none of the electronic temperature displays come on. Robert
    Guru:
  • 462 Answers
Your Compressor is not running and the overload is the tick click I'm believing follow these steps below to help you decide:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} . To Decide if Either your compressor is broken inside or the start components are not working properly.
Parameters’ are as follows and must MUST be true before continuing:
1 Condencer coil (outside coil) Clean and open for a ir flow
2 Condensor Fan motor is running and turning at enough speed and correct direction.
3 Voltage to the compressor is correct and supplied.
4 Decide if the compressor is Hot or warm or cold to the touch for future reference.
Cold or Hot
Could it be the compressor not running or that it has overloaded?
If you suspect the compressor try to follow this to decide your next step:
These little helps allow you to get the compressor running or decide that it needs replacing
1 Ohm the compressor terminals to ground and across to each other.
A. If any read anything to ground the compressor is bad. No Need to go further.
B. If the compressor is hot and you read through some points on the compressor motor (pins or terminals) but not through others wait up to 24 hours for an internal over load to reset. Internal type, usually AC and larger Refrigeration Compressors. Smaller refrigerator type compressors have an external over load. After 24 hours off or yours has an external overload re-ohm and see if all have readings to each other. If these read open IE No resistance between each other the compressor is bad.
Results your looking for:
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
After 3 or 4 tries if the results don’t add up the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Get a new Start relay (start capacitor if so equipped) relay and overload (and run capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration..
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 18, 2009
    Problem Solver:
True commercial refrigerator opened it up and is warm 70.F looking at motor was buzzing with a rubber burning smell ok,spun the fan motor and came on (works) ,now why did this motor stop in the middle of the night is there more problems ahead thanks.
Posted on Jul 03, 2010
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
My 5 year old GE profile refigrator stopped working today. it has been making a ticking noise and the unit won't come back on. I unplugged and replugged and nothing happened. theres no tempeture lights on....
This problem sound to me like the timer is stuck on defrost. That is the only control on the refrigertor that makes a ticking noise. Try to manually advance it.
Mar 22, 2010 | GE Profile PSS26NGS Side by Side...
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE Profile side by side
also ensure the condensor uder the fridge is clean of dust build up. high head preasure at the compresor discharge can also cause noises in the eveperator circulation. make shure you clear out this dust 4 times a year.
Aug 06, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer not working again!
here is link my trouble description:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/2538-clicking-noises-back-ge-refrigerator-2.html
Mar 08, 2008 | Refrigerators
GE Profile PSS26NGS Side by Side Refrigerator Logo
523 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
