Question about Hardware & Accessories
I have an MTD8 timer, that fits into my main electrical board
I have an MTD8 timer, that fits into my main electrical DB board, to control my hot water cylinder. The instructions that came with the timer seem incomplete, where can I download an instruction booklet that makes more sense. I presume the same chip is used in a number of different timer configurations.
Dave Cross, Cape Town.
  • cdabie May 11, 2010
    what were the instructions
    Scholar:
  • 122 Answers
MTD8 Timer - Instruction manual
1. This timer has a total of 8 ON / OFF programs.
2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
3. Switchable 12 / 24 hour mode.
4. 16 timer combinations are available as follows:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Mo, Tu, We, Th, Fr, Sa, Su
Mo, Tu, We, Th, Fr
Mo, We, Fr, Su
Mo, We, Fr
Tu, Th, Sa
Mo, Tu, We
Th, Fr, Sa
Sa, Su
Initial operation:
1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
2. The settings can be defaulted by depressing the R (reset) button.
Setting Current Time.
1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
2. Release both buttons. The weekday and time will be set according to your selections.
3. To set incorrect time (etc.) repeat the settings.
Settings for programs:
1. Press the Timer button (Clock) and release. The first ON setting can now be made.
2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
When setting block dates, the ON and OFF times apply to all dates in the block.
I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
Posted on Jun 07, 2011
  • Anonymous Jun 17, 2011
    Wizzard: there are 7 square buttons and 1 round rest button. What are the markings on each button and position of each button? Your answer mentions 4 buttons: Clock W H M and reset button, but does not talk about 3 of the buttons.
  • Wizzard 300 Jul 06, 2011
    Button markings:
    Top row - Left to Right: W+, H+, M+, RES/RCL
    Bottom row - Left to Right: C+, ['Clock' symbol], R (reset)
    Reset is the round recessed button.
See if timer appears on following links: (1) http://waterheatertimer.org/Woods-timers-and-manuals.html#seven (2) http://waterheatertimer.org/Boxtype.html
Posted on Apr 29, 2011
Maytag neptune dryer pf code
it sounds like you have a bad computer board if it's stuck on 19 minutes and the pf is for power failure,this is only a guess,the best thing would be to call in a tech to check it so you know what the problem is,the board is expensive or you can order the board from repair clinic,if it's not the problem you can send the board back to them.did your power go out for some reason like a storm or something?this can take out any computer board
http://www.repairclinic.com/PartDetail/Main-Control-Board/33003028/1164529
Apr 10, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Tip
Component failures on Maytag Neptune Font Load Washers such as the pressure...
Component failures on Maytag Neptune Font Load Washers such as the pressure switch, wax motor, hot and cold water valve solenoids, timer motor, 24 VDC circuit, and the overall electrical buffer circuit have significant effect on the machine control board. Failed resistors on the control board can be used to determine failed washer components. Resistor R9 is associated with the pressure, R11 is for the wax motor, R51 for the hot water valve solenoid, R52 for the timer motor, R53 for the cold water valve solenoid, R143 for the 24 VDC circuit, and R162 for the overall electrical buffer circuit. The TRIAC Q6 is also associated with the wax motor while TRIACS Q3, Q9, and Q17 are for the timer motor, cold water valve solenoid, and hot water valve solenoid respectively. These TRIACS must also be replaced should the corresponding resistors have failed or burned out.
on May 17, 2010 | Electrical Supplies
Tip
Maytag Neptune Front Load Washers Machine Control Board Repair
Component failures on Maytag Neptune Font Load Washers such as the pressure switch, wax motor, hot and cold water valve solenoids, timer motor, 24 VDC circuit, and the overall electrical buffer circuit have significant effect on the machine control board. Failed resistors on the machine control board can be used to determine failed washer components. Resistor R9 is associated with the pressure switch, R11 is for the wax motor, R51 for the hot water valve solenoid, R52 for the timer motor, R53 for the cold water valve solenoid, R143 for the 24 VDC circuit, and R162 for the overall electrical buffer circuit. The TRIAC Q6 is also associated with the wax motor while TRIACS Q3, Q9, and Q17 are for the timer motor, cold water valve solenoid, and hot water valve solenoid respectively. These TRIACS must also be replaced should the corresponding resistors fail or burn out especially when there's no power going to the associated component.
The most common problem experienced is the failure of the wax motor as indicated by the inability of the washer to advance to the high speed spin cycle with the "door locked" light not lit. Replace the TRIAC Q6 and the resistor R11 on the machine control board to get the machine back into operation. Use MAC97A6 or NTE5656 for Q6 and a 3.9 kilo-ohms carbon or carbon film resistor for R11. It is recommended to install a 1/2-ampere pico fuse in series with the wax motor to prevent damage to Q6 and R11 should the wax motor shorts out and fails again.
Replacement of the wax motor is a must before installing the repaired or new machine control board to prevent damage to the repaired or new part. Make sure the wiring harness connections of washer components are good and snug fit. Reseat the connectors several times to clean off corrosion build up both on the connectors and terminals.
on May 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
How to set the timer
MTD8 is 240Volt din rail timer max load 15 amps
Copy following link to identify timer and download manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE22
Oct 17, 2012 | Major Hardware & Accessories
I HAVE 3 NOS DB IN DIFFERENT LOCATION FOR LIGHTING HOW TO MAKE 1 TIMER PANEL TO CONTROL THOSE 3 LOCATION OF DB
What is NOS DB?
You want to control 3 locations of lights using 1 control panel.
Are you going to run wire from each light to the control panel?
Are you using 120Volt or 240V? What voltage are you using?
Model number of control panel is unknown, and which timer is inside control panel is unknown. Copy following link for overview of control panels.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Aug 05, 2012 | Intermatic 40 Amp Control Panel & 220V...
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Jan 10, 2010 | Whirlpool GY396 Electric Kitchen Range
Dryer will not get hot
check the main power cord to make sure it is connected. and that you ahve the proper power to the unit.you can also check the thermal fuses located in the cabinet.or you may have to replace the main control board.
Sep 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Hot water valve not closing
there's a water level sensor which sends the electronic signal to the control board to close the valve. There's tiny little pipe going from the top of the drum. at the end of it, the level sensor.
Also make sure you've used Normaly Closed type valve (NC).
None of above? then it's the control board
Jul 19, 2009 | Hotpoint Washing Machines
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Hardware & Accessories Logo
2,347 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
