Question about Canon EOS 400D / Rebel XTi Digital Camera
Error 99! Wont' take picture, the message states
Error 99! Wont' take picture, the message states turn off and turn on camera again or remove battery and install again. None of these works. Do you think I need a new battery?
  • Anonymous Apr 24, 2009
    no se puede disparar,
  • Anonymous May 21, 2009
    yep i have an error 99 too- what does it mean?
  • 65 Answers
Go to the www.canon.com website and find out what Error 99 means. ted10
Posted on Apr 20, 2009
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
Here is what Canon said :
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
I hope this will help
please don't forget to rate !
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 message keeps popping up
Instead of taking battery out, open and close battery department to reset camera.
Sounds like you have a major fault, you should raise this with Canon and prob send for repair
Jun 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Error 99 on 30D Canon
Had this problem before and i found this guide online
camera body.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
483 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
