Question about Sceptre X42GV-Naga 42 in. LCD Television
Volume too loud
The volume setting for television on number one is super loud but zero is mute. No range?
Very likely the volume setting on your cable is set too high. The cable volume is separate from the TV volume. Once you lower the cable volume, then you can adjust your TV volume to find a happy medium that gives you more range between numbers. Have you already tried this?
Posted on Apr 22, 2009
Volume on Samsung stuck at zero
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
Aug 25, 2016 | Samsung Televison & Video
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
Minute timer is not loud enough. It was but now volume low.
Set the timer to 1 minute and then press the minus button to zero it.
This makes the timer 'beep'.
If it is quiet, press the minus button again and the volume of the beep will alter, running through 3 settings - loud, medium and quiet.
Jun 04, 2011 | Rangemaster 90D Range
Randomly my volume is as loud as it can get no matter what. Whether the volume is on 1 or 60 it is blaring. Turning the volume to zero is still muted...anything I can do to fix this problem?
I turned my television off and unplugged it for a few hours and when I plugged it back in and turned it on... the volume worked like normal again. Woo
Nov 18, 2009 | Durabrand DWT2704 TV
Sharp MX-3501N ---- My copy machine you can hear sending out the fax, it dials and then sends and then beeps really loud. Is there any way to shut the sound off so we don't hear the fax go through?
There's a Key Operator setting for muting the fax speaker. Press the 'system settings' button, then the Key Operator button to enter the access code to the key operator settings (default is all zeros),
Find the Fax settings button and then the fax default. The option to mute the speaker should be within the speaker volume settings.
Aug 18, 2009 | Sharp Office Equipment & Supplies
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
No sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Jan 10, 2009 | Dynex DX-LCD37 TV
Polaroid FLM-323B HDTV Loud Buzzing
Hi.
If your happy to remove the back casing of the the TV set.
Lay set face down on table with several towells laid out flat under it.
Undo all screws holding back on & lift it off you may need to remove tv stand to remove back.
Once back is off either locate speakers & unplug the leads from them remember to insulate the loose wires & tie them up out of the way.
Or trace wires from speakers to there plugs & sockets on main Pcb & unplug them & thats it.
Screw rear of set back on & ensure volume is set low or at zero.
http://dysonmanuals.llc.nu/
Jul 13, 2008 | Polaroid FLM-323B Television
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Sound Stuck on High
change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Aug 03, 2007 | Toshiba 19A25 19" TV
Sceptre X42GV-Naga 42 in. LCD Television Logo
750 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
