Question about Brother MFC 420CN All-In-One InkJet Printer
Black Won't Print On MFC 420 CN
I had surgery and my Brother Printer stayed idle for almost a year. I changed cartridges today and cleaned 5 times, all colors work, but not black. Is there some other way to clean the print heads as I assume this is the problem.
  • PoppaDick Feb 05, 2008
    I didn't have surgery and mine didn't sit for a year. It sat needing ink for a couple of weeks. Now ...same problem. Very faint print, I've cleaned and cleaned. It got better, but it still isn't right. Help! I've hardly used this thing in the year I've owned it! (but it has always worked well until about a month ago when I refilled the cartridges)
OK folks, here's a success story for a change. I have a MFC 420CN. I also refill my own ink cartridges. I previously had a similar printer stop printing black and cyan which left me with a useless printer. When my black stopped printing I thought here we go again...so I read a few posts and then tried something.
I went to Office Depot and bought a pack of Inkjet Printer/Fax Cleaner Sheets (Part # 470041) for $13.99. I bought a bottle of 70% Isopropyl alcohol ($2.50) and went to work.
First I put a cleaning sheet through the printer but it didn't seem to do much so I added a little extra alcohol to the sheet and ran it through a couple of times printing a page full of "B"s in bold font.
I then took an old black cartridge and an empty ink re-filling bottle (with the thin needle on the top) filled with isopropyl alcohol and then filled the cartridge with the alcohol.
I then ran 100 pages of printing the "B"s in bold font. After a while the printing came back and then got fainter and fainter. Finally, I put my old black ink cartridge back in the printer and printed 50 of the "B" pages.
My black is working fine again! Give it a shot for less than $20.00!
Posted on Feb 08, 2008
  • 832 Answers
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Posted on Sep 18, 2007
6ya staff
SOURCE:
Instead of black its green
Hi. Color cartridge is defective and need to be replaced
Feb 04, 2018 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Hi, I've changed my Brother printer ( MFC-495CW) inobella recently but the color black dose not work. what to do?
this happened to me, too. printer starting using all of my yellow ink.
The ink container was the problem, defective. it took several changes for it to print in black again...5-10 cleanings.
make sure the black cartridge is not defective by trying another one in it's place. if you can, use the yellow for the black slot, then switch back a few times ( I tried to re-install the drive, but the in was the problem). Good luck.
Oct 27, 2010 | Brother MFC495CW
Won't print any black. new cartridges installed with same result. help!
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother DCP-350C InkJet Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Black Ink Cartridge
I don't the meaning of the word "clogged" but the better way to clean a printhead is to put hot water on a soft clothe and gently put the cartridge on and off a couple of time. You will see if the cartridge let ink leaking. Important do not scrap with your clothe under the cartridge.
Mar 08, 2008 | Brother MFC-3240C All-In-One InkJet...
Hi Steve.
Yes your are right:
Stay away from older brother printers due to an developer mistake in the construction.
Better buy the latest modells with LC51 cartridges. Brother had learned their lesson, too and did a very good job with those new printers!!!
Give the old mfc3240 away to eBay for example.
Nov 22, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
480 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
