Question about GE 28112EE2 Digital Answering Machine
Caller id wont work displays no data, how do i get it to work again
Caller id doesnt works only displays no data , is there a way to reset this or get it working again?
  • 1 more comment
  • dantecooks Apr 18, 2009
    it was working fine i use magic jack for my provider it just recently stopped showing data
  • Mike C
    Mike C May 11, 2010
    Have you changed any of your equipment or changed the port to which you connect your phone? As magicjack is a VOIP provider, it may be that your USB connection is not providing enough power to drive the function.
  • Mike C
    Mike C May 11, 2010
    Have you subscribed to Caller ID function with your provider?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Always ensure that your equipment is plugged into a POWERED USB PORT/HUB to ensure that functions such as Caller ID work.
Posted on Apr 18, 2009
How can i set up caller id
If you have the Caller iD service on your plan, and your phone is filled with your contacts, then the two work automatically and calls coming in on your list will be displayed as you entered them. Calls without any info will only display the most basic of info they allow like just a name, or just a number. Sometimes neither if they choose to block Caller iD. Caller iD is a cellular service and not a hardware function. Check with your service provider.
Aug 29, 2015 | Cell Phones
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
Seimens Gigaset AL285 BSNL caller ID not working
The source of my caller ID not displaying was a faulty ADSL filter.
For some reason my ADSL filter blocked the caller id information - but worked fine otherwise.
When I changed the filter the caller ID worked fine again.
Jun 05, 2012 | Siemens Lands Phones
Caller id is not displayed anymore
i dont know how your sistem ist working. Im just looking for a instruction for the RX-DS45 to change or add the radiochannel
Sep 02, 2009 | Panasonic KX-TG6500 Cordless Phone
Caller ID doesnt work anymore
see if it is turned off at the provider. ring and ask for the codes to turn them on and off.
May 30, 2009 | Uniden TRU9480 Cordless Phone
Caller ID on EXT phone
First device on the phone line will read hold and confirm receipt of caller ID, there is no data passed to secondary devices.
This is not a fault, this is system standard
Jun 28, 2008 | Brother IntelliFax-2820 Laser Fax
Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Mar 12, 2008 | Panasonic (KX-TG1032S) Phone
No caller ID displayed
If your cable service is transmitting the caller id data, and the phone has that feature and is working properly, you should be getting the caller id after the second ring. The only way to confirm where your problem lies (the phone or the cable service) is to take your phone to a regular phone line with caller id and see if it works, and vise versa. My guess would be that the Panasonic phone is working fine on a regular phone line of which it was designed to do, and the problem is in the cable carrier not conforming to industry standards. But I may be wrong.
Dec 29, 2007 | Panasonic KX-TG5632 Phone
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
GE 28112EE2 Digital Answering Machine Logo
474 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
