Cuurrently attempting to charge sweex MP439 using USB provided. When attached to computer can download music, play, edit and change settings. Once disconnected the MP3 cannot be switched on. Also I ensured the switch at the top of the MPe was switched to the "on" position. Additionally, when connected the MP3 displays a battery icon but no animation to indicate that it is charging. Can you help?
  • kemet01 Apr 18, 2009
    Thanks for the solution but it is far too generic. I need a solution derived fom an expert with experience/knowledge of this make of MP3. Additionally the LCD works perfectly while attached to the computer via the USB.
    Thanks. However, once disconnected the MP3 switches off and cannot be turned on in order to switch it off again and connect it to the computer via the USB.
    I connected the MP3 to the computer, it powered up, displayed the battery icon (however, no animation to indicate charging) and I held the on/off button down for 3 seconds but there was no effect. If I disconnect it, it will shut down and will be unable to be turned on.
    Any ideas?
  • 916 Answers
If the device powers off right after removing it from the computer and when connected the battery icon shows no animation the battery needs to be replaced. You should be able to get it replaced pretty cheap at any local electronics shop. Other than that there really is nothing you can do. If it is a new player return it for an exchange under the warranty.
Thank you for using FixYa! Please Rate!
Posted on Apr 19, 2009
    Genius:
  • 1,011 Answers
Dear,
try it by switching off and then connect it to pc through usb cable
Switching off
Switching off the Sweex Black Pearl 1,5" MP3 is done by pressing the  button for 3 seconds. You can use the main switch on the back of the device to
prevent the player from being switched off accidentally.
regards,
Posted on Apr 18, 2009
  • SALMAN NASEER Apr 29, 2009
    dear,
    did u perform what i suggested...
    regards,
    Brigadier General:
  • 3,614 Answers
this could be a problem oh the lcd display of the unit. the unit need to be serviced and need to be check by technician.
Why will my sweex clipz mp3 player not turn on?
Perhaps you thought you were hanging the battery, but the battery already died. So to won't give any power. Try to switch it on while charging and then unplug it. When it switches on, you know the switch is still working. When it dies as soon as you unplug it, your battery must be replaced. (or buy a new MP3 player)
Jan 27, 2015 | SWEEX Clipz MP303 2 GB Flash MP3 Player -...
Tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
on Aug 09, 2011 | Apple iPod touch
Cant seem to be able to download music onto it off computer didnt get any instructions with it
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer step 2 Press the home button on the PSP step 3 Use the left and right buttons to find Settings ( select by pressing the X button ) step 4 Select USB Connection -Your computer will notify you that a new USB device has been connected This should show up as a new hard drive with a corresponding letter identifier step 5 On your computer, select the correct drive letter and open PSP file system step 6 Create a new folder and call it PSP step 7 Go inside this new PSP folder and create another folder. Name it MUSIC step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created step 9 Disconnect the PSP from your computer by pressing the O button step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC - Select Memory Stick by pressing the X button You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP. http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
All the best to you my fellow PSP enthusiast.
Jan 26, 2011 | Sony PlayStation Portable (PSP) Slim...
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Having problems with downloading music to the mp3 player
It needed to use windows media player and had to sync with that alls working well.
Dec 27, 2009 | Audio Players & Recorders
How do you download music from our computer to the
It is hard to provide any useful suggestions without knowing the type of cell phone your son is using.
Normally he would put the memory card in the cell phone microSD slot (provided it can support 2gb card), plug the USB cable from computer to cell phone (if it supports this). Normally the phone will have also got some software apps CD which should be loaded to computer. This will provide the necessary functions to load music files to the phone.
Alternative to USB is bluetooth connection which both the computer and the cell phone will have to support. He can transfer music files that way.
I am not sure if he can copy the files directly from the computer to the memory card and play it on the cell phone as data formats are not standard. Also iTunes files need to converted to mp3 format. If these are protected iTunes files then it becomes a bit harder - best to burn a CD and then rip into mp3 format.
Once again these suggestions are useless if cell phone cannot play music (mp3 or WMA etc) files, does not have microSD slot, does not have USB or bluetooth support.
Dec 24, 2009 | PNY 2GB microSD Memory Card
I've recently purchased a 8GB Sweex mp439 player. It's cheap and it works well until the battery runs out. I plug it into the usb port and it won't charge! how can i solve this problem?
I had the same problem and had to take the device back. I got a replacement but that hasn't worked at all, it just says "Loading" and never goes any further. I am going to get my money back.
Jul 05, 2009 | Audio Players & Recorders
Asus A7V8X-MX SE and Sweex CR005V2 connection problem
download the latest software from the manufacturer's website, and install the software *BEFORE* plugging the usb device into the computer. the installer will tell you when to plug the usb device in. once it tells you, windows will automatically detect the device and install the proper software drivers if you are patient!
Sep 23, 2008 | Computers & Internet
Unable to sync new music to player
I had a similar problem with my daughter's mp3 player, here is how I was able to fix it:
1. download the firmware software from here
2. unzip & install the software from step 1.
3. remove the battery from your mp3 player
4. start the software
5. hold down the play/pause button while attaching the mp3 player (via usb cable) to your computer
6. once the software's button labeled "start" is activated you can set down the mp3 player (you don't need to hold the play/pause button anymore).
7. check the box to format your data area (this will remove the mp3s, but is needed to get this to work properly again)
8. Click start and follow the on screen instructions
This worked for me... also, make sure your directory names + filenames are not overly long as this seems to be part of what is causing this problem.
Feb 23, 2008 | Memorex MMP8567 MP3 Player
185 people viewed this question
 Grubhead
Grubhead
