Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My whrilpool refrigirator went out while I was gone for a week.
We have a side by side and the ice melted and it is completly dead. the lights on the front work. It is about 7 years old and a pretty cheap one(came with the house). what should mt next step be?
    Guru:
  • 462 Answers
Start by seeing what else works.
Power check:
the compressor. The fan beside the compressor.
If no power find thermostat or control board and see if it has directions on checkout procedure. Sometimes the information is in an envelope under the front kick plate and sometimes its in an envelope on the back or underneath.
This may get you started.
Sounds like a board or (if it has the older style defrost control) timer has stuck in the defrost possission.
Look inside at your thermostat contol. remove the knob and look behind this area. A thermostat type control will have a metal tube coming around to the air inside the refrigerator. You can then put the 2 wire ends together and see if it makes the compressor come on. If so replace it if not then your down to the defrost check. Find the timer it has a cam on the motor gear and can only turn clockwise with a screwdriver. try this until it clicks and re check it then.
An electronic type control will only have 2 wires very small and no metal tube (these may have a small metal sensor about 1" long that is metal but thats all). This type requires a set of steps to check out. And you will need to measure the resistance on the probe at a given temperature. The correct measuremaents are on the check out sheet and usually at 32'f (set the sensor in a glass of ice water for 10 to 15 minutes).
This should get you to deciding what to do next.
If you lack the tech and life skills to follow these instructions I suggest you allow a qualified servicer look at your refridg.
Hope this helps you and plaese rate me as high as you cn thenk you for using fixya.
Posted on Apr 18, 2009
  • Farley Redfield
    Farley Redfield Apr 18, 2009
    Power check:
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
Ice maker and hose from back of fridge to it both frooze up.
Good day,
If the fill tube overfilled the ic maker and is iced itself, it is due to the water valve in the bottom rear leaking slightly after filling the ice maker during a normal cycle. The water valve will have to be replaced. However, it will take time and patience to get it thawed properly.
The ice maker should be removed and set aside to thaw out completely.
As well, the fill tube must be thawed out itself very carefully. Haste makes waste here. A hair dryer can be used but very sparingly since it's possible to start melting things you don't want melted.
Ideally the machine should be shut down but that's your call.
Once the new valve is installed and the machine reassembled it should be fine.
May 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Refrigirator side not cooling but freezer side is working, fan is working
if you open the freezer back wall you see that there is ice all over that prevent colld air go to the fridg.
use hair dryer to melt all the ice (turn unit off)
then you might need to replace the heat unit or the thermostat in the freezer to prevent it to build ice again.
Dec 28, 2009 | Kenmore Refrigerators
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
WATER LEAKING FROM THE FREEZER INTO REFRIGIRATOR
Remove back wall from the inside of the freezer. Some models you have to remove the floor first, others you don't. There will probably be a lot of ice so have plenty of towels and hot water ready. It may take quite a while to get the ice to melt completely, but in my experience it is ALWAYS ice. Just keep refilling the pan with super hot water, and poke into the drain hole with a cable tie or pipe cleaner. When the water feels like it has gone cold, wipe it up with a towel, and refill the pan with hot water.
Jul 27, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We had a ice storm and power was off for nearly two weeks, wont d
When the power was off for that long period of time all of the ice in the dispenser melted. When the power came back on, any water remaining in the ice cube bin froze into a solid block.
If you raise the wire arm up and leave it up, no new water will come into the icemaker. Do that.
If there is a block of ice in the ice cube bin, use a blow dryer to melt it and discard it. Once the ice is gone, spray the auger with some PAM or other cooking spray to lubricate it a little bit.
Finally lower the wire arm down and wait up to 12 hours to get ice making normally again.
Feb 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
143 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
