Question about Sony Ericsson W700i Cellular Phone
My bluetooth range has some problem,it doesnt conects from a far distance it should be kept closely 2 other device
  • 530 Answers
Friend your bluetooth device is faulty. You can replace it with the new one. Ask mobile technicians help for this matter to avoid further damage. good luck friend
Posted on Apr 18, 2009
Bluetooth is not responding
which bluetooth device ? are you referring to ?
keyboard , mouse , ahh a webcam ?
Bluetooth is a wireless technology that connects devices over a limited-range network (WPAN, or wireless personal area network). Bluetooth transfers data three to eight times faster than a parallel or serial port.
Some Lenovo PCs includes an internal Bluetooth card to allow users to connect Bluetooth devices to the computer. Inactive Bluetooth support or computer settings can prevent the Lenovo PC from detecting a Bluetooth device.
Hold down "Fn" and "F5" after booting the computer or returning from standby to enable Bluetooth features. Click "Start." Click "Control Panel." Double-click "Bluetooth Configuration." Select the "Accessibility" tab. Check "Let other Bluetooth devices discover this computer." Select "All devices" from the drop-down menu. Click "OK." Double-click "Bluetooth Devices." Select the "Options" tab. Check "Turn discovery on," "Allow Bluetooth devices to connect to this computer" and "Alert me when a new Bluetooth device wants to connect." Click "OK." Exit from "Control Panel." Align the device with the Lenovo PC. Check the documentation included with the device to confirm it is the correct distance from the computer. Right-click "Start." Click "Explore" or "Open." Navigate to "My Bluetooth Places." Click "Bluetooth Tasks." Click "View Devices in Range" to locate the device. Select the device from the list. Click "Discover services" to use the device's applications on your Lenovo PC. Right-click the device and select "Connect" or "Pair" to configure the device. Hope it helps.
Jan 25, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
Magic sing chordless microphone registers "sync' in display. The microphone will not function. If I move close to the module, it will activate again. But if I move far, it goes back to...
Hi danbrielle ,
Depends on the range of your player , if you are able to hear sound properly from a range say 2 meters and it shows disturbance when you go far away , that means the distance that you are from the cordless player is too much for proper and clear sound .
I recommend you to get the best out of your player by keeping it close to you , so that there are no hurdles in sound.
Hope this helps....:)
May 10, 2011 | Audio Players & Recorders
How do i turn on bluetooth with a htc wildfire
Bluetooth basics Bluetooth basics Bluetooth is a short-range wireless communications technology that allows devices to exchange information over a distance of about eight meters without requiring a physical connection.
Turning Bluetooth on or off Turn off Bluetooth when it is not in use to conserve battery power, or in places where using a wireless device is prohibited, such as on board an aircraft and in hospitals.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Select or clear the Bluetooth check box.
Mar 05, 2011 | HTC Wildfire Cell Phone
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
My mobile bluetooth does not works properly
In real, its a fact my friend bcoz each mobile has its specific bluetooth range.
So as per my openion its a limitation of the bluetooth & no one can do anything in this case bcoz the range is fixed to that model no one can change it.
its a basic rule that when 2 bt.s are in range then & then only it works,if u take it far from another it does not work.
Nothing to worry .Enjoy ur BT.
Aug 13, 2009 | Sony Ericsson W700i Cellular Phone
PLEASE HELP: Fuzzy when too far away from phone (2ft)
Check your maual to see how far the distance is on the headset. Also, things like alot of electronics can weaken your sync signal.
Jun 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bad range
Actually, you are using a Class Bluetooth adapter which can go up to Up to 330 feet (100 meters) wireless working distance. It is compatible with Class 2 (33 feet/10 meters) and 3 (3.3 feet/1meter) Bluetooth devices but it will follow the short range. Your moto h375 headset is a Class 3 device so it should go only go up to 3.3 feet indoor (line of sight).
May 09, 2009 | IOGear GBU321 Bluetooth Wireless Adapter
Bluetooth
Well BT is only a VERY short range device 2 - 3 feet or a metre or so is about normal... unless one has a high power BT...
Jul 18, 2007 | Sony Ericsson W800i Cellular Phone
Sony Ericsson W700i Cellular Phone Logo
47 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
