Question about Whirlpool Duet GHW9150P Front Load Washer
Long wash cycles
I have a front load duet washer and dryer. when i start a load of clothes the timer will say 40 min. to finish it will take about 2 hours for the machine to stop i never get a error code during the cycle such as suds i hate this washing machine! any ideas?
WHEN YOU WASH IS THE WATER HOT ENOUGH IN A REASONABLE TIME? ALSO DOES THE WASHER SENCE THE AMOUNT OF SOAP THATS IN THE TUB. IT COULD BE GIVING ADDITIONAL RINCES TO REDUCE THE SOAP CONTENT.(TRY WITH NO SOAP IN SYSTEM AND SEE IF TIME IS SHORTER)
Posted on Sep 18, 2007
6ya staff
SOURCE:
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
I have a duet HT and the control is locked. how do i unlock thanks
Mine is doing this all the time, I finally got tired of pulling the washer out to unplug it so I plugged the washer into an extension cord that's easily accessable, so unplug it for at least 30 mins before you plug it back in reset to drain and spin cycle for 12 mins and your load should finish ok. These washer and dryers are beginning to be a pain in my....neck.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open...
try unpluging it for 3 min then set the cycle knob to the 12 oclock and power it back on
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
Can I make the water level on my whirlpool duet washer higher?
its because of the design of the machine they are water efficient.a front load uses any where from 15 to 18 gals. compared to 40 to 50 gals.for a top load. they also have a higher spin rate than the top loader,therefore making your close dryer and having a less drying time in the dryer.energy efficient too!!
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
276 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
