Question about Brother IntelliFAX 2800 Laser Fax
2800 WILL NOT RECEIVE FAXES BUT WILL TRANSMIT
Help!! It has to be something with the settings. It's on a dedicated fax line; we've been through the manual. We've also tried the plug and unplug scenario & it hasn'nt worked.
  • kaplan Dec 05, 2007
    checked phone line, there is a dial tone
  • eharris Dec 12, 2007
    how do you get the fax from manual to auto to receive fax's?
  • 163 Answers
There sir your fax is may be in mannual receive put it in auto receive
Posted on Sep 21, 2007
SOURCE:
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I am not getting my faxes
Is this business line part of a network, vs. just being a straight phone jack? If that's the case it won't work.
Needs to be on a dedicated /direct line.
Apr 28, 2009 | Brother IntelliFAX 2800 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot receive faxes or copy, but can send out
make sure you auto recieve light is on.
check your lights the one for FAX only has to be on only.
not TEL or FAX_TAD
good luck>
Mar 21, 2009 | Brother IntelliFAX 4100 Laser Fax
Here is the answer fixya...
not TEL or FAX_TAD
good luck>
Won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Dec 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Phone hookup
First only plug the line in the LINE socket otherwise it wont receive.
Manual receive will probably be the best as conflict may occur with the answering machine and the fax. You will either not receive faxes or messages. Its a bit of a pain as you will have to be home to receive faxes. eg pick up the handset and press start.
Its the easiest. Unless you want to fiddle with both machines settings to use the fax/telephone mode.
Mar 13, 2008 | Brother IntelliFAX 2800 Laser Fax
Disable receive mode on FAX-2800
NO the best solution is to turn fax machine off after hours
Jan 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
