Question about PANDIGITAL (DPF802) Digital Picture Frame
I have a Momento Wireless Digital Photo Frame, and there seems to be no power when switching on. I have checked the power adapter and it works on other device.
2 Suggested Answers
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
Why wont my digital photo frame turn on?
If you have not already done so, try another power adapter. In some cases, the cord between the power rectifier/step down transformer (the part that actually plugs into the AC outlet) and the connector at the frame end, becomes kinked or broken. The connector at the frame may also have become worn and not propely connected? If a second adapter does not work then the unit is faulty. Take it to your nearest service center for repair. (it may be less expensive to purchase another digital frame?)
Dec 20, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
Digital photo frame not switching on. Worked yesterday but not today. Would it be the adaptor or the frame itself, how can I find out?
If the adapter works with another device then the frame is bad. If the frame works with another power source then the adapter is bad.You can also measure the voltage between the contacts on the output end of the adapter to see whether you're getting any juice out of it when it's plugged in.
Apr 17, 2012 | Cameras
Manual for digital photo frame brookstone
There is mention of the fault that is seen on the frame and if there is no power at all it is due to failure of the adapter or the power supply which can be checked using a multimeter. In case of loss of display check on the inverter circuit , the link cords and the connectors.
Dec 19, 2011 | PANDIGITAL 7" Digital Photo Frame With...
I have a nextar N7T-106 photo frame and it will not power up. What can I do?
It is possible that the power adapter does not work. I have two identical to yours send me a msg to courrierloader(att)gmail(dot)com
Oct 19, 2011 | Nextar N7 - 7 Digital Photo Frame with...
Where can a get a power adapter for my 10 inch digital photo frame that was lost? do you know the part number
Bring the photo frame to Radioshack. They have a large selection of universal adapters and can help you get one with the correct size tip and voltage.
Feb 27, 2010 | Philips PhotoFrame -10 Digital Picture...
Frozen Screen on Digital Photo Frame
I have the same problem!!!
Did your frame already work?
Feb 15, 2010 | Philips 6.5-Inch Digital Photo Frame...
No power
1) Try different wall outlets.
2) Turn the dial on the frame both ways to make sure the backlight brightness is not turned all the way down.
3) Test the AC adapter with a voltmeter.
If the adapter does not work, replace with one of the same voltage and amperage.
If the adapter does work, grab your receipt and go back to store or call the company.
Jan 06, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
PANDIGITAL (DPF802) Digital Picture Frame Logo
197 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
