Question about XFX NVIDIA GeForce 8600 Graphics Card
Blank screen The graphics card fan turns on and powers up when i plug it into my Dell Dimension E520 but no matter what i do there is always a black screen with my moniter, theres no problem with my screen or my PSU. A reply would be highly appreciated
  • 7 more comments
  • Anonymous Apr 18, 2009
    No its always running, its a XfX geforce 8600gt 1gb , there seems to be problems with this card with many other users in similiar situations but no solution yet from what i've read , thanks for the reply, btw the computer sound like its starting up and loading
  • lewis_2_6 Apr 18, 2009
    Sorry about the guest post
  • lewis_2_6 Apr 19, 2009
    hi thanks for the responce , appreciated , i've sent the card off now anyway to see if its compatable and to be installed , if not im sending it right back , dont suppose youknow any good alternatives , thanks
  • Anonymous Apr 28, 2009
    hi there
    i have the same problem fans are spinning on graphics card with a blank screen when powered up
    graphics card palit ati radeon 1 gb pci express 2.0
    need help plz........
  • zanzix24 May 02, 2009
    whenever i try to power up my comp with this graphics card in it, all that happens is my card runs the fan very loud, i get a blank screen and no sound. my comp doesnt even run bios, it works perfectly fine with other or no graphics cards. but with my 8600 it just does nothing but the fan.
    this occured after i unplugged my comp in the middle of a restart session (not the best idea i know :P)
    same happens to me, this occured after i power-pulled in the middle of a restart if that helps any.
  • Leng Yang May 11, 2010
    Well for right around the same price range 90-130 bucks, you can get yourself the ATI Radeon 4850 card (one of their top of the line cards) for right around that price... or you can get a higher end geforce card for right around 100 bucks too like the higher 8 or 9 series cards. Especially the 9 series cards have come down on price significantly and you're getting ddr3 member on them also, so you can't go wrong with that.
    With my best guess, you can always try to see if a different card works (so you can eliminate anything else system-wise) if you do get a picture.
    If that dummy card works, try this one again but reset the CMOS to see if that will clear anything up.
    If that doesn't work, try this card in another system to see if it works.
    If that doesn't work, then I would contact XFX to get an RMA (they should be open today if I'm not mistaken)
    Is the fan on your card always running throughout the entire start up or does it start, then stop turning?
Hey I am also facing same problem.But My card was woorking fie before yesterday.
I bought a new CPU cabinet> so had to remove nad reinsert the GFX card and it giving me the same problem as you are facing....
i.e. the fan is moving but screen is blank
Help plz.
Posted on Apr 20, 2009
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
My E520 Dell shuts down in to the energy save mode after 1 minute of booting and then the high speed fan comes on and screen goes black
off the energy save mode...it goes revert of ur action...re-install opreating system..is it work? clearfy
Mar 16, 2012 | Dell Dimension E520 PC Desktop
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
I added a 4 port usb card to a dell e520. The
try updating the drivers to the card to see what happens. another solution is try it on another computer. if the same problem exists on another computer you could have a bad card.
Mar 30, 2010 | Dell Dimension E520 PC Desktop
No power on dell e520 dimension
On the 20 pin connector, short the green wire to any black wire with a paperclip. This will force the power supply to turn on manually if the motherboard is not giving the correct "ON" signal.
Feb 26, 2010 | Dell Dimension E520 PC Desktop
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
I cant git sound
If your monitor is fine try changing the data cable to one you know to be working. If it still does not work then the graphics card needs to be replaced.
May 29, 2009 | Dell Dimension E520 PC Desktop
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
XFX NVIDIA GeForce 8600 Graphics Card Logo
301 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
