Question about Danby DWC440 Wine Cooler
Adding Freon to the Wine Cooler
Seems like we have the same problem as other folks. Freon must have leaked out. 1) Can freon be recharged at home? 2) Exactly how can it be done? 3) What freon do we use? Thank you - M
  • 1 more comment
  • Anonymous Nov 12, 2007
    was cooling fine for about two years, then no more cool. Compressor can not be heard cycling off and on as before. A click once in a while. The compressor feels hot to the touch , but not cooling inside. Help!!!
  • PhotoWiz40 Nov 21, 2007
    We're having a party and just noticed the cooler wasn't working (temp inside 75ยบ )
    The previous question about adding freon - does not appear to be answered? What can be done?
  • Anonymous May 28, 2008
    danby wine cooler is not cooling - can freon be added -
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Posted on Aug 20, 2009
  • 14 Answers
SOURCE: leaking water from the back
make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
Posted on Apr 10, 2008
  • 172 Answers
SOURCE: Danby Silhouette Wine cooler won't
Hi sooner84,
I really like the Danby wine coolers, they are usually nice products. As far as your problem, I would first try to find out where the main problem area is. To do that first make sure that your compressor is running. If the compressor is running and it is not cooling then you may have a freon charge issue. Thats not to say that you can just put some more freon in and it is fixed, You would have a leak in your sealed system and you would most likely still have warranty coverage for that. Most Danby products carry a 5 year sealed system warranty. That would include your compressor.
If the compressor is not running then you would know that you have a compressor issue. Either the relay overload on the compressor would need to be replaced or the compressor itself was bad. You can buy relay kits for about $30.00 and intall them easily with very little experiance.
Next if the compressor is doing its thing and trying to cool you could have a fan not blowing air properly. either a condenser or evaporator fan may have stopped. If you find one not working then chances are you just need a fan. If the fans are blowing and the compressor is working then you would just have a defrost problem. In that case you would just need to defrost then check for bad parts, either a defrost heater, defrost thermostat or a defrost timer. Most of the Danby products have a defrost control board, that board willl contorl the defrost, the temperature, and the fans. If the board was cheap I would say just put one on and see if it fixed the problem, but they are around $145.00.
The most important thing for you would be to make sure you are not going to do something that would void your warranty. Free service is always the best. Good luck to you and send some wine my way, I make lots of different types. from grapes, strawberrys, muskedyne, etc.... mca0824@aol.com
Posted on May 02, 2008
How hard is it to add freon to a wine cooler?
Don't attempt it, need special equipment, seek additional quotes but if it's leaking them there is a gas loss issue. You should never need to add gas to a fridge that is sealed in the factory.
Askntechnician why it needs a gas top up? It must be leaking from the pipe work. Adding gas wont solve the problem, you need to find the sauce of the leak to remedy the problem longer term.
Mar 22, 2014 | Whirlpool Furniture
I have a frigidare #PLKU1267DSO kegbox. the compressor runs and gets hot but the box will not cet cold at all. the coils inside also have rust on them
Your keg box runs very similar to a Wine Cooler. I believe this can help you. The pressure for the freon and the steps for trouble shooting is he same. Give it a try.
Danby Wine Cooler Repair Recharging your wine Cooler with 134a Freon
Feb 19, 2012 | Refrigerators
The unit is a Breezeaire wine cooler. The evaperator is freezing up.
MOST LIKELY A FREON LEAK ALMOST 90% OF UNITS WITH FREON LEAKS DEVELOP ICE BUILD UP ON THE FRONT COIL, AND AFTER A PERIOD OF TIME IT GOES AWAY AND THEN UNIT RUNS NON STOP GETTING WARMER AND WARMER TILL IT HITS ARROWND 70 T0 72 DEGREES.
Oct 02, 2010 | Breezaire WKL 4000 Wine Cooler
I have the 8000 WKL Breezaire it has started to frost up over and over. I turn it off to melt and it starts to frost as soon as it starts to cool the wine room. Why?
IF THE BLOWER ON THE COLD SIDE IS NOT RUNNING THAT WOULD BE THE REASON WHY THE COIL FREEZES UP AND IT COULD BE DUE TO A BAD BLOWER CAPACITOR LOCATED ON THE BACK OF THE UNIT LEFT SIDE (SMALLEST OF THE TWO OVAL CANISTERS), BUT IF THE BLOWER IS RUNNING ON THE COLD SIDE IT MOST LIKELYIS A FREON LEAK, AND UNIT NEEDS TO BE RECHARGED WITH FREON AFTER REPAIRING THE LEAK.
Sep 27, 2010 | Breezaire WKL 4000 Wine Cooler
How do you add freon?
adding freon is not the answer unless you can prove you have lost some. The unit is hermetically sealed so should not lose freon unless you have punctured the system and the gas has escaped. you will probably need a fridge expert to test and check over the system.
May 17, 2010 | Haier BC112G Wine Cooler
How do I replenish the Freon in my Sillouette model DWC283BLS?
you legally can't unless you are e.p.a. certified to purchase the type of freon in the unit and you have the equipment to do so,by law you need to evacuate the sealed system,then pressurize system with nitrogen and a small amount of r22freon,find the leak,recapture nitrogen/r22 and repair leak,then recharge unit with correct amount of correct refrigerant it needs,the equipment to do so is very expensive too
Nov 19, 2009 | Danby Silhouette DWC512BL Wine Cooler
Unit was leaking at rear coil, sealed the leak but know it needs freon. Can it be added?
All fridges, freezers, coolers, etc need access ports added to them before any refrigerant can be added to them. Makes you wonder how they do that eh?
May 29, 2009 | Avanti WC54 Wine Cooler
Danby DWC440 Wine Cooler Logo
4,125 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
