Question about KitchenAid KUDM01FK Dishwasher
Dishwasher door will not stay closed, even when not in use.
Door keeps popping open during wash. Door will not stay closed when not in use.
5 Suggested Answers
  • 7 Answers
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Tom
Posted on Jan 14, 2009
  • 901 Answers
SOURCE: The dishwasher door keeps popping open
Check the hinge area. May be some hard washed materials could have got stuck in-between. use a light / torch and observe.
Posted on Apr 12, 2010
rylee_smith
  • 8619 Answers
SOURCE: Door keeps popping open,will not
Hi
Thanks for using FixYa. As you have already replaced everything else so the issue is with the door switch going bad and should be replaced however, if that switch is fine then it is the control that is bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 21, 2010
oldTech2332
  • 2341 Answers
SOURCE: the dishwasher door keeps popping
The catch on the door latch assambly is weak and the latch needs to be replaced, this vidoe will show you how to replace the latch,the part# is 8183830 it could be purchased at your local appliance parts store or online at,searspartsdirect.com assuredaprts.com apdepot.com
repairclinic.com appliancepartspros.com
Posted on Aug 08, 2011
Electrolux dryer eied50liwo door keeps popping open during drying
The latch mechanism is not fulling grabbing and the door pops open. By bending either the door mechanism or the chassis mechanism so parts are tighter you can restore proper operation.
Sep 04, 2015 | Electrolux Dryers
How to reset code to turn up the heat on a dishwasher model #WDT9105AYE
You can't turn the heat up, just on or off. Are you using heated dry?? It sounds like the vent system in the door is either not working or blocked. Some dishwashers have a small trap door flap in the dishwasher door that is closed during wash and opens to vent steam during the dry cycle. Sounds like it is staying closed. If you have a higher end dishwasher, they usually have a fan motor that come on during dry that gets rid of steam and moisture. Just a few things to check.
Feb 16, 2015 | Whirlpool Dishwashers
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Kitchenade Dishwasher. Door keeps popping open during cycle. replaced both the springs and cable in door. door locks but then pops open during cycle.
Try adjusting the door catch, this is the hook that comes out from the top of the machine and clips into the door switch when closed, it can be adjusted further out by loosening the screw. If not then you may need to replace the door switch. This is done by unscrewing th front panel and removing it. The switch is held on by 2 screws and 2 wires. Hope this helps.
Mar 02, 2011 | Dishwashers
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
GE Profile Performance Dishwasher soap dispenser doesn't open
most likely the solenoid that releases the door open or the spring that pops the door if defective.  It may even be a bad timer.
Check your yellow pages for parts and prices.  It may not be worth it to fix a 10-year old dishwasher.
Why don't you just lay the tablet inside and close the door.
Mar 07, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Kitchenaide dishwasher latch will not stay closed. It pops open during washing cycle and the machine stops and does not complete the cycle
The dishwasher was not properly leveled on installation. I used a carpenter's level
and trued up the problem. The door now stays closed.
However, the latch design is faulty in that it does not ever feel securely latched and that is true of all the Kitchenaides that I tried in the showrooms.
Jul 19, 2008 | KitchenAid Dishwashers
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher DI450 Door
Hi chrissy99
Not sure what do you mean by keeping the door to stay open. Well if you want to keep the door open during operation , identify the mechanism that triggers the on button .
In my dishwasher to check if it function properly , I keep a small wedge / strip near the handle / button which opens the door.
Dec 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
KitchenAid KUDM01FK Dishwasher Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
