Question about Nikon N70 35mm SLR Camera
Film is not loading automatically
I've followed the instructions to load film but when I depress the shutter release button the only result is the lens rotates a bit. Frame "1" doesn't appear when it should, instead "12" is there. No error messages are present.
  • 371 Answers
That's not a "12" but halfway between 1 and 2, so it would pay you to have your camera aligned by a pro.
Posted on Apr 26, 2009
When I insert the film, it won't catch, therefore I keep winding until the roll is done (also, the shutter release button won't depress). What does this mean? Is there a way to fix it?
When you say 'vintage', are we talking 35mm or roll film ? If 35mm, looks as if the interlock between shutter release and wind-on spool needs adjusting, but no idea if this is possible.
Aug 31, 2015 | Kodak Vintage Automatic 35 1959-64with...
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
Loaded film, but when to have film developed it was blank
The most common cause is that you didn't load the film correctly.
Hold the camera up to the light with the lens off and the back open. C0ck the shutter ready to fire and press the shutter release as you look through the camera towards a light source. If you see light briefly appear then the shutter is working and you would get some kind of image on the film, even if the shutter was wildly inaccurate. If there's no light, then repeat at all shutter speeds. If you see nothing then the shutter assembly is faulty and the camera effectively becomes a spare part donor as it's not a cost effective repair. If there is some sign of life then the camera probably just needs a good CLA service (Clean, Lubricate, Adjust). Again, not really cost effective, but you do end up with a solid and reliable camera for many more years.
Faulty film loading even catches out experienced photographers, we've all done it. In future, after you load and wind-on the film, check that the rewind crank turns counter clockwise each time you wind the film on to the next shot (you may have to turn the crank clockwise, gently, to take up any slack first).
Aug 29, 2011 | Pentax K1000 35mm SLR Camera
Hello. I just got a Mamiya C330, looks really nice but I note that the little release botton in front of the camera is inside I can;t take it out. my question is this could affect to take picture or I...
This button you speak of is an alternate way of depressing the shutter it is also a way in which you can use a shutter release cord to take pictures. the button itself is not meant to come out of the camera. Once you load your film or 2 empty film spools (to test to see if the camera is working properly) into the camera and wind the film crank then you will be able to depress that button and fire the shutter.
http://www.butkus.org/chinon/mamiya/mamiya_c330f_prof/mamiya_c330f_prof.htm
Aug 10, 2011 | Mamiya C330 F Professional TLR Film Camera
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank...
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
May 10, 2011 | Pentax ME Super 35mm SLR Camera
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Nikon N70 35mm SLR Camera Logo
207 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
