Question about Samsung LN-T4061F 40 in. LCD HDTV
40"smasung hd tv won't turn on anymore
Started about a month ago taking longer and longer to actually get a picture. now it just clicks and won't turn on
Mine was doing the same thing. Opened it up and had 2 bad capacitors on the power supply board. If you take off the back it is the board in the center. The bad caps are seen by a slight bulge on their end. The ends sticking up have a cross shape imprinted on them. They should be totally flat. The bad ones will be swollen slightly. The bad caps on mine were 2200 uF 10 volt. Note the orientation and replace. They are very cheap. Just use the high temp ones. 105C. Took me less than an hour to replace and be back up and running.
Posted on May 28, 2009
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2016 | Samsung Televison & Video
TV Rarely Starts
Check all the solder terminal at its main power regulator section circuit. Any loose solder terminal can poise this type of problem. Resolder all the suspected solder terminals by applying a little more solder. If you wish to get more details, check this site.
Apr 22, 2013 | Hitachi 32UX01S TV
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Samsung 40" lcd sound but no picture.
May be the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
Jul 21, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Takes awhile for tv to come on!
Hello Ruben,
This type of failure is common on these TVs. The power supply might need to be replaced due to bulging capacitors. If you are able to replaced the capacitors, it is a cheaper alternative.
Check the link below to find service parts.
Jun 12, 2017 | Televison & Video
Doesn't turn on
Pretty good chance the power supply board is bad. A number of capacitors will become leaky and you lose all power. Some techs still know how to do component Laval service but most just change the board $$$$
Jul 10, 2008 | Polaroid FLM-2601 Television
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Oct 18, 2007 | Sony KP-53V85 53" Rear Projection...
Tv making a loud crackling
The set should be under warranty, call the company or go on line and get a servicer out asap. good Luck
Mar 19, 2007 | Polaroid FLM-3232 Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
462 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
