Question about Palm Treo 755p Smartphone
Treo 755p how do i erase information on the phone so that I have more memory on my phone?
  • Anonymous Feb 25, 2008
    I would like to know how I may import and out import music to my phone when I do not want the music anymore, and also how can i import from an mp3 how do I do this. Please e-mail me at Marcflores1@yahoo.com all call me at 646-342-9545
  • Anonymous Mar 22, 2008
    Cannot find where to even start process
On the main screen, touch the time at the top left, and you will see "app" and delete shuold be right under it.. click or touch it and you will see a list of apps to delete. make your choice, adelete.. I hope this helps.
Ion
Posted on Jul 10, 2008
  • 21 Answers
There is many answers to that but they require more information what do you have excess of saved to your phone. What is the information application that you want erased?
Posted on Nov 13, 2007
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
Tried the hard reset for Palm Treo 755p. It asks to erase data. I say yes. And then nothing else happens. Anyone try anything else? Is the phone done?
yes it is hard reset already it is the normal behavior
pls rate me fixya for the help i provided or tell me ur issue in detail if u want anything else
Mar 04, 2009 | Palm Treo 755p Smartphone
My palm treo 755p
Dhorner64 is incorrect. Your phone is not fried if you are in a restart loop. You need to do a "warm reset" which will not erase data. It is the equivalent of doing a safe boot in Windows. Remove the battery from your 755p, then put it back while holding the up button on the 5-way. Hold the up button as the phone starts. I had to do this frequently, then run the DataViz Tech app, which is available free from DataViz, to fix their prefs file, which was the source of my crashes. The problem was solved by upgrading to Docs2go v11. I was reluctant to pay to upgrade a crashing app, but the upgrade ended the frequent crashes. I have not had a couple resets since upgrading Docs2go, and no reset loops.
Nov 23, 2008 | Palm Treo 755p Smartphone
Treo 755 with epocrates
I found that when I moved epocrates off of the storage card and into main memory, it didn't have any boot problems any more...
Sep 09, 2008 | Palm Treo 755p Smartphone
Palm 755P Freezes
Well, thank God I had done a recent Hot sync! I found out how to do a hard reset by holding down the power button while reinserting the battery then letting the button go and the system will ask if you want to erase all data? I put yes! Then it erases all my data and restarts the phone. I had to plug the phone in to be recharged because the looping ultimately drains the battery. Then, I plugged in the Hot sync cable and pushed the button to start the sync and ta da! back to its working state! Yippee! Do it! It's easy! Just make sure to hot sync often so your info stays current!
Aug 26, 2008 | Palm Treo 755p Smartphone
Treo 755p screen freeze
Sir U ve to Flash ur phone: its look like to install a new OS in it .u need a tool called box phone its expensive just repairman use it. so seek for one or use our ones by using this repair service and put ur zip code of area.
rate me plz^^
Aug 05, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
Tranferring ringtones from SDcard to palm treo 755p
You can use a FREE program for the palm OS called minitones, you can yahoo or google it, which will allow you to convert mp3s you have on your SD card or on the phone to a ringtone that you can assign to a contact. minitones.prc
Mar 23, 2008 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
153 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
