Question about Garmin iQue 3600 GPS Receiver
When GPS is turned on unit locks up
I have a 3 year old unit that still has the original battery. Even though the battery shows a full charge when I flip up the build in GPS antenna or connect an external one the screen flashes on & off 13 times before unit locks up and then has to be reset before usable again.
  • 2 more comments
  • gbenham Sep 26, 2008
    Didi this happen even when you have a power source other than the battery?
  • Captain Wolf Sep 28, 2008
    I haven't noticed any screen flashing or flickering, but when I flip up the GPS antenna on my 3600, it finds the location and then within a second or two, locks up and requires a soft reset. I loaded R6 about a year or so ago to resolve what I remember to be a similar issue. Anybody have any ideas on where to go from here? Judging from their website, Garmin appears to have misplaced the meaning of Customer Service.
  • NotAZero Dec 07, 2008
    I don't think the software matters with this issue and here is why I think this...I have used battery power and my car adapter. My battery is in very good condition and will run for 30-45 minutes on the battery with the GPS on. The first thing I did was remove the SD card that has all of my maps installed. When I go to the map icon it shows on Long/Lats and no land masses at all. So the map function is working but there is no software maps running. My Ique 3600 will shut down right after it locks on to 3D. My GPS stayed in 2D GPS for about 30 seconds and it ran fine and showed me on the map with the Long/Lats. I have even tried letting the battery completely die so I lose all my addresses and then charge up the battery in hopes of "resetting" the GPS, no luck. My GPS will work fine with the antenna down and not using an external antenna, both where tried with the same results...locks up. I have no additional software loaded on my GPS other than the factory software. Is there anyone out there who owns one of these, had this issue, and fixed it???
  • Anonymous Feb 08, 2009
    I have a 3 year old iQue 3600 that just started freezing up shortly after it locks on to 3D. A soft reset will work but shortly after it locks on to 3D it freezes again. I had loaded Release 6 quite some time ago and decided to load it again this morning. That did not correct the problem. My unit has the original battery which still seems to function properly - however it is being powered by the cradle in my car when it freezes. I have not tried it running on battery only to see if the problem still exists (my guess is that it will still freeze). I also tried decreasing the map resolution but that did not make any difference.
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Posted on Feb 03, 2009
  • Anonymous Feb 03, 2009
    The setting is Preferences... GPS.. remove check from WAAS Enabled
    Problem Solver:
  • 4 Answers
To be precise, the setting is Home -> Que -> GPS -> Preferences (under QueGPS) -> WAAS Enabled: remove check from box to disable.
Posted on Oct 31, 2009
  • ChileRellano Oct 31, 2009
    Oh, and one other thing: After unchecking the WAAS Enabled box, turn off your Garmin iQue 3600 and perform a soft reset by pushing the concealed RESET button on the back of the unit with the small reset pin found on the end of the black plastic cap of your iQue stylus after it is unscrewed.
  • 26 Answers
Replace the battery, had the same problem and replacing the battery stopped the screen flash and constant resetting.
Posted on Sep 25, 2007
I had the same problem and was able to fix it by ugrading to latest ver 6.
Posted on Sep 19, 2007
SOURCE:
Laptop works great on AC input, Battery charges and discharges per the indicators but will not power up on DC only. What needs replacing?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 03, 2013 | Fujitsu LifeBook S6231 Notebook
Battery will not show full charge,when charging it say`s it`s charging.?
you could try taking out the battery and restarting everything might just need a reboot
Sep 27, 2012 | Garmin Nuvi 660 GPS Receiver
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
I was given a garmin ique 3600 but i plug it in how do i know its charging
It lights up on top. Then the litle battery icon will show with a lightning bolt.
Nov 20, 2009 | Garmin iQue 3600 GPS Receiver
Why does my garmin nuvi 205w keep shutting off?
The most common cause is low battery.(no voltage to the unit)
Does it shut off if plugged in and not moved?
If you have a old battery it may show a full charge while having only a surface charge and of course....will shut off.
Also if it is plugged in and the connection is moved causing a bad connection .....even for a second while having a bad battery in the unit ....it will ...of course ....shut off.
Nov 03, 2009 | Garmin nuvi 205W GPS Receiver
Yesterday, when driving, I noticed that the device said i was receiving no signal, even though I was out on the interstate... I got frustrated and turned it off... I figured that it would give it ample...
The green light does not necessarily mean there is power to the unit or charging the battery. If the unit is more than 3-5 years old, you may have success with replacing the battery. If you have a power source with sufficient current output capabilities then you could try that with the battery removed.
Jun 16, 2009 | Tomtom GO 910 GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Jun 20, 2008 | Magellan GPS
Suddenly turning off
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Nov 28, 2007 | Garmin Edge 305HR GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
380 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
