My washer come on but it don't spend i have model: whdsr316g1ww
  • 121 Answers
Check your lid switch
Posted on Apr 18, 2009
Banging noise comming from back of washer near the belt
I have a GE WHDSR316G1WW top loading washer and the drain hose located on the upper left rear of the plastic outer tub came loose. It sounded like a worn seal or bearing because it was banging so loud. I removed the control panel, top panel and front panel, reattached the drain hose into the housing hole and the problem was solved. Saved $80 service call.
Aug 15, 2013 | Kenmore 24032\24036 Top Load Washer
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
Feb 24, 2013 | GE Washing Machines
My model is whdsr316g1ww thewasher willnot spin also it fillup with water and now will not wash
It could be an inline fuse located in the wiring harness that runs along the right side of the inner panel under tons of electrical tape. If it has a motor inverter board ontop of the motor, check to see if there is a green flashing light, if not, then the fuse may be at fault. If so, there is probably an issue with the motor/inverter board assy or the lid switch.
Nov 20, 2010 | GE WBSR3140DW Top Load Washer
My washer won't agitate or spin! I hav a GE washer model # whdsr316g1ww
Might be a blown line fuse located in the red and white wire in the harness, you will know it if the green idiot light on the motor ain't a blinkin.
Got questions? I will be here all week.
Rate the answer and thanks fer using Fixya!
Mar 13, 2010 | General Electric WHDSR316G Top Load Washer
Cannot get drive belt on ge washer model #whdsr316g1ww
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
Feb 25, 2010 | Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
hi, reset the printer.
open th right door,without paper then close the door
it work
thank you
May 17, 2009 | General Electric WHDSR316G Top Load Washer
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
Loud draining
hello mam please clean the drain filter and check the noise if you feel the same then please change the drain pump.
Mar 01, 2009 | General Electric WHDSR316G Top Load Washer
GE washing maching model #whdsr316g1ww
sphion effect,,you drain hose is to low,,pick drtain hose up at least height of unit before,,it can go down,,,onthejob
Jan 08, 2009 | General Electric WHDSR316G Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
