Question about Samsung V20 XVC 2400 Notebook
Samsung v20 on bootup the screen just stays white.not able to see operating window
  • andyroo Sep 23, 2007
    Tryed the brightness keys this is not the problem,
    also i haqve connected my samsung v20 on to another moniter and things ok. Please could anyone help with this problem
I thing it's problem of connector of lcd (internal, on motherboard), the connector need to be re-weld/soldering, check it before (pins break?)
I have this problem and resolved by weld pins/soldering pins with soldering iron (white connector with data video cable part and screw from lcd screen, not from internal pc on motherboard)
Posted on Dec 30, 2007
    Sergeant:
  • 457 Answers
Isnt there an adjustable switch on the side of the screen that can lower the brightness?
Posted on Sep 18, 2007
  • Peter Hirawani
    Peter Hirawani Sep 23, 2007
    Well if its going with another monitor the problem lays with the LCD? these people might help: http://lcdrepair.net
SOURCE:
Samsung sens v20 laptop power on but no display
Any sound? Does the HDD led blink during start-up? Can you hook it up to a external display? If so, what is on the screen?
Nov 27, 2013 | Samsung V20 XVC 2400 Notebook
My NC10 netbook works normaly until i try to run it with the power cable plugged in ...the screen goes blank (white)...unplug the power and it runs OK. roger.
first thing i to check psu model specs,(should be on sticker on psu) is as supplied with your model(manufacturers site)
Sep 11, 2010 | Samsung V20 XTC 1800 Notebook
My v20 screen stays white as it tries to boot up
did you sort this problem out with the white screen mine is doing the same
Sep 24, 2009 | Samsung V20 XVC 2400 Notebook
The Samsung V20 Notebook doesn't have screen Output after Start. One button clip of the keyboard button --> is missing. Is there a dependance between keyboard function and screen?
no, but if it got knocked hard enough to mess up the keyboard there is a good chance that something has happened to either the gpu or the screen itself as well.
Aug 14, 2009 | Samsung V20 XVC 2400 Notebook
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
Hi, i have a samsung v20 laptop.2 questions...
I have a Samsung V20 for many years and I know it doesn't support a wireless connection built in. But if you connect a USB like myself you can have access to the internet wirelessly. The flikering on the screen are you sure you haven't got a screen saver switched on, you may have it set to a clear black screen and like you say have to tap the keyboard and it comes back to life. It may also have hibernation switched on which will automatically turn off the screen have so many minutes you can change all these setting by right clicking on the desktop and selecting properties and under the screen saver tab there will be a power btton you should see hibernation and other tabs across the top these can be altered to whatever you want.
Hope this of use.
Dec 05, 2008 | Samsung V20 XVC 2400 Notebook
Screen fault on samsung v20
screen tube or inverter board faulty.
change the inverter board, then replace the CFL tube.
Or replace the whole tft screen.
Mike @ Compurepair.
Jul 09, 2008 | Samsung V20 XVC 2400 Notebook
Blank screen, greyish/white
Could you explain more in detail what the problem is, what laptop do you have?
Thanks
Dec 28, 2007 | Samsung V20 XVC 2400 Notebook
Samsung V20 XVC 2400 Notebook Logo
119 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
