Question about Dell 1815dn All-In-One Laser Printer
Dell 1815 network scan problem- can print but not scan or see it
- Dell 1815 mfp connected to small business network
- Works perfectly on all computers in office, including 1 Dell with Vista Business and all others running xp pro
- Problem on 1 computer network scan will work for a few minutes then quit- I can ping the printer and print to it but cannot re-connect to it or see it using the dell network scan software
- details of computer where dell software does not work:
- lenovo w500
- 2.8 intel chip
- 4gb ram
- norton 2009 antivirus- dell network scanner program listed as allow
- windows firewall off
- windows vista 32 bit business
network-
- netgear business router and switch
- no other problems
Summary- I can print to printer and scan for a few minutes upon initial startup of computer, but then the scanner disappears and cannot be found.
I have tried to get help from dell but they pawn it off saying my machine is out of warranty, even though in 12-2007 I purchased a 3 year warranty and have the receipt, the warranty department has not updated status yet. Any suggestions would be appreciated.
  • Alex xol Aug 28, 2013
    I have a dell 1815dn. I used the driver for dell 2145cn. it worked for me...
    in case you are using Windows 8. try the driver for 2145cn
    Master:
  • Dell Master
  • 552 Answers
Dear
Pl. check your internal system ip address, take the configuration sheet of the printer to know its address and use it and should not match with other.
Thanks.
Posted on Mar 08, 2015
McCuskerCo
  • 8 Answers
SOURCE: Dell 922 Printer
You will have to use the New Dell 922 VISTA drivers and not the XP drivers in order for it to work with your Vista Loaded PC. The new drivers for the 922 under Vista are available for download at Dells website. Check out this link http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/dsn/en/document?c=ed&docid=314972&l=en&s=bsd Hope this helps.
Posted on Jun 25, 2007
Drummernick
  • 440 Answers
SOURCE: Scanner Problems After Installing Windows Vista
ya its vista issue i have same one my dell works half butt most of tiem also cuse of drivers aint relly made for vista keep looking on dell site for new vista drivers only ever other week its updated ok
Posted on Feb 03, 2008
Fixe_You
  • 1800 Answers
SOURCE: Dell AIO 924 Printer/Scanner Wont work with Vista
try to download the compatible driver for Vista!!
using the page of ur product starting with dell.com
Posted on Dec 12, 2008
lea0101
  • 62 Answers
SOURCE: dell 1600n will not connect
One of the most common problems when networking is adding the correct subnet address. To check your computers.
Click on start
click on run
type in the box "cmd" (no quotes)
click in the black dos box and type
ipconfig
This will tell you the ip address and subnet of your computer.
The ip address need to be different for the computer and the printer but the subnet address needs to be the same
Posted on Mar 06, 2009
  • 11 Answers
SOURCE: Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Posted on Apr 28, 2009
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
I have a Dell laser mfp 1815 dn. There is not an option to scan to a pdf. It will scan to a bitmap which is not what I need. How do I get it to scan to a pdf?
When you save the scan select pdf from the pull down menu "Select Type of Document" in the Save Dialog.
Hope that helps.
Jul 23, 2011 | Dell 1815dn All-In-One Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Cant scan via network?
You cannot use the paperport software to network scan. The paperport software is looking for a driver that is not installed. Network scanning for this printer is basically just file sharing. You initiate the scan at the printer itself. It scans the image and puts it on your computer. After it is there, you can use paperport to convert it to text if need be.
Jan 15, 2009 | Dell 1815dn All-In-One Laser Printer
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
2,471 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
