Question about Siemens SpeedStream 2624 (SS2624) Wireless Router
SET UP How do I set this up??? I am about to order Cox internet and am buying a Motorola SB5100 Cable Modem and I am new to the whole wireless thing, except using it for my laptop in hotels. thanks!
    Problem Solver:
  • 12 Answers
Please contact us for help we can walk you thru this
Posted on Sep 23, 2007
SOURCE:
The wireless connection is not working. The only network that shows up is lynksis wich has a waek connection and asks for a password that i have neever had to use before, so i dont know what the password...
Unfortunately the Motorola SB5100 SURFboard is not a wireless device. The Linksys you are trying to connect to is most likely someone in your area and they have it password protected, which is why it is asking for a password.
In order to setup Wireless you will need to invest in a Linksys, Netgear, D-Link, or some other Wireless Router. They can be found at any computer store.
Once you have the wireless router you can connect an Ethernet cable from the Motorola SB5100 SURFboard to the Wireless Router. From there follow the instructions for the Wireless Router you purchased to set it up and secure it.
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Dec 22, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need new ip and mac adress for sb5100 motorola for southwest
To get new IP unplugg power for 1 minutes the plug the power back in. MAC address is a unique identifier specific to that modem. To get a new MAC address you will have to buy a new modem.
Sep 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Moto modem to Linksys wireless router
You have to reset the modem from behind (little pin hole) with the modem and router not connected via ethernet, the let it restart and reset the router after both are reset connect the ethernet cable between them.
Nov 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Reloaded Windows Vista
you can try the ff:
► double check the wireless if it's enable or disable. click start > start search > windows mobility center > turn the wireless network ON.
1) reinstall the wireless driver of the computer using the driver disc or using the recovery partition....
2) tried to set-up the home wireless conenction in "Home Set-up Wireless Network" and follow the instruction.
3) reseat wireless card if it's reseatable.
4) download the BIOS update using ethernet cable from the pc website support.
3) contact Internet Service Provider.
4) reinstall the windows to the factory condition.
Sep 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Open Questions:
See all Siemens SpeedStream 2624 (SS2624) Wireless Router Questions
Siemens SpeedStream 2624 (SS2624) Wireless Router Logo
163 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
