Question about Foxconn 661FXME Motherboard
No graphics on monitor whatsoever, screen completley blank
I have a foxconn 661fxme motherboard, pentium 4 prosessor 3.00 GHZ 533, on power up there is no bleep but everything else sounds to be ok on startup. when i got the motherboard it had no button battery so i put a new one in and cleared cmos with jumper then set back to normal. checked monitor and cable with laptop. tried 4 different graphics cards plus the on board graphics card, and still no change. the chipset is SIS964L, bios is phoenix bios D686.and the front pannel seems to be working properly lights and everything but now im stuck does eneyone know what could be wrong becouse i havent a clue. please help
  • 1 more comment
  • stelff Apr 19, 2009
    i have 1bank of ram in slot 1 it is samsung 512MB DDR PC3200
    CL3 KR M368L6523CUS-CCC
  • John Elliott
    John Elliott May 11, 2010
    The only difference I see between the chip you are trying to use and the chip that is specified for that motherboard are the voltages. That Samsung chip has a voltage of 2.6v and the specs recommend 2.5v - generally this shouldn't matter but some boards are more sensitive than others.
    You might want to try a PC2100 or PC2700 chip in the board to see if it will post for you also...
  • John Elliott
    What type of ram memory do you have in the board? If you can provide a part number off the chip(s) I can do a quick search to see if it's compatible with the board.
    It sounds as if you have done your troubleshooting on the problem correctly so far though, as well as the CMOS reset, which I would have recommended had you not already done it...
    Problem Solver:
  • 11 Answers
I think there is a problem with your system's hardware.. check whether your MOBO or your processor.. computers that doesn't startup and has no beep has defective or burned CPU or motherboard
Posted on Apr 21, 2009
Can an HP Pavilion a305w imperial GL_VE 20021218 137001 motherboard with a celeron 2.7 ghz 400 mhz intel processor be upgraded to a pentium 4 2.66 ghz 533 mhz processor?
Yes as long as it is the same case stile and 400 mhz.
Base processor Intel Celeron 2.7 GHz
  • 400 MHz Front side bus
  • Socket mPGA478
    Note.... Make sure you use PC2700 memory PC2100 will give you error messages
May 22, 2014 | Intel Computers & Internet
Foxconn 661FXME - PC661M04-G-6L & Intel pentium 4 prescott 511 2.80 ghz
Hello you can download a manual from here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000108&Language=en-us
But BE CAREFULL when you change the cpu.
And remember to add some cooling paste.
Here is some info about the cpu:
http://ark.intel.com/products/27452/Intel-Pentium-4-Processor-511-1M-Cache-2_80-GHz-533-MHz-FSB
You will get better performance with a new mainboard/cpu
as this cpu only has one core.
Good luck
Oct 06, 2012 | Null Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Is it possible to put PCI videocard on 661fxme
The motherboard supports AGP to 8X so yes is the answer.
Sep 26, 2009 | ATI All-In-Wonder Radeon 9600 AGP...
WHAT KIND OF PROCESSOR COMPATIBLE TO FOXCONN P4M800MO1
you can enter in your Mb any type of intel processors ranging max speed bus 800 mhz , for example you can enter intel pentium 4 hyperthreading 3.00 ghz , 800 mhz front side bus 1 mb cache, number 530, 530 j or better than him.
Apr 08, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Foxconn 661FXME Motherboard Logo
383 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
