Question about Samsung CLP-500 Laser Printer
There is a "CTD Calibration Error" at display! where is the "ctd"?
    Problem Solver:
  • 8 Answers
CTD detects the amount of toner on the drum and is used by the printer to determine charge levels required for good image production. It is a part of the transfer belt unit and cannot be replaced on it's own. First try removing and refitting the transfer belt, making sure the electrical contacts are clean and undamaged. If that doesn't work, fit another transfer belt.
Posted on May 04, 2009
Where is trsnreceiver in 99 cadillac sts
Anti-theft system transceiver ?
Theft Deterrent System
The Theft Deterrent System on this vehicle is comprised of two separate systems, the Personal Automotive Security System (PASS-Key?® III) and the Content Theft Deterrent (CTD) system. These system are described and diagnosed separately within this section. For CTD operation, refer to Content Theft Deterrent (CTD) Description .
SECURITY Indicator The yellow indicator SECURITY on the instrument cluster is controlled by both the PASS-Key?® III system (VTD module) and the CTD system (RIM).
PASS-Key?® III system, the VTD commands the instrument cluster to control the indicator only when the ignition switch is ON.
CTD system, the RIM commands the instrument cluster to control the indicator only when the ignition switch is OFF.
PASS-Key?® III System The PASS-Key?® III system is designed to help prevent vehicle theft by disabling the engine unless an ignition key with a specific electrical value is used in the ignition lock cylinder. The PASS-Key?® III system operates independently of the CTD system. Protection is provided even if the CTD system is not armed. The components of the system are the ignition keys (black or gray), ignition lock cylinder, Theft Deterrent (VTD) module, Reader Exciter, Powertrain Control Module (PCM) and two starter relays (START 1 and 2) in the underhood fuse block.
Oct 06, 2016 | 1999 Cadillac Seville STS
Ctd sensor error
The protection sheet on the imaging unit is probably still on, remove that and the error should go away.
for more help visit CBR Tech Solutions
Jul 11, 2013 | Xerox Office Equipment & Supplies
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Apr 10, 2011 | Office Equipment & Supplies
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
I had a 'clean the ctd sensor' error. Cleaned it now it prints half the page in watercolors.
I had a clean the ctd sensor problem as well, as a problem with toner that I had ordered. The problem for me was that with Dell, when I called for support, the young lady on the other end of the phone although nice, was difficult to understand, and did not clearly define how you get to the ctd sensor.
After much prayer, (seriously!) I finally figured out how to get to the area I needed. With Dells instructions, I took the fuser out, thinking it was the transfer roller. The fuser is NOT the transfer roller, the transfer roller in the item that you see when you open the front entirely and look straight down. The difference is that the fuser is the first item out and has lift up blue tabs, while the transfer roller has blue tabs on each side that must click into place to hold and position the transfer roller properly. Once you get this out the ctd sensor is easily accessible, and can be cleaned. After, getting the ctd cleaned, and then replacing the bad toner cartridge, my machine once again worked.
Sherry McGregor Timberwood Mountain Realty,
Jul 09, 2009 | Dell 5110cn Laser Printer
CDT Calibration Error
CTD (not CDT) stands for Color Toner Density Error. Your bad sensor is not on the printer, but on one of the color toners.
Oct 15, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
935 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
